rebuild
rebuild
Postby TX1GEN » Fri Oct 12, 2012 9:11 am
gotta '93 club cab, that i traded a transmission for, hit a little hard on the cab..then the rebuild started
http://i1145.photobucket.com/albums/o50 ... f03104.jpg
http://i1145.photobucket.com/albums/o50 ... 5f64cd.jpg
TX1GEN
Re: rebuild
Postby TX1GEN » Fri Oct 12, 2012 9:18 am
TX1GEN
Re: rebuild
Postby dazedandconfused » Fri Oct 12, 2012 9:20 am
Where did you find the replacement panels for the cab? Didnt you pick up another cab to use? Never mind the pics showed up.
Re: rebuild
Postby JD91 » Fri Oct 12, 2012 9:34 am
:cheers: :cheers: :cheers: sweet progress bro :cheers: :cheers: :cheers:
91 w250 RC, getrag, 4in turbo back diamond eye
93 D350 CC, getrag, 4in diamond eye, 60# springs,3200 gov,arp's,fass 150,fass sump, BD SUPER B 58MM, 5x14 sticks, M&H timing spacer, cut fuel pin,valair clutch, auto meter pyro & boost......she screams!!
91.5 d350 RC, getrag, cut fuel pin, no bed lol "the beater"
75 dodge club cab swb flat bed 4x4 "gasser" on 37's
JD91
Re: rebuild
Postby TX1GEN » Fri Oct 12, 2012 9:39 am
ya got another cab, thanks to your advice 8)
the new cab, had rust all on the roof above the drip rail, we cut some metal off a door and patched that, came out nicer than i expected
TX1GEN
Re: rebuild
Postby dazedandconfused » Fri Oct 12, 2012 9:41 am
Every cab ive came across is rotted there.
Re: rebuild
Postby TX1GEN » Fri Oct 12, 2012 9:44 am
oh ya i looked at several cabs after you mentioned the vin plate wasnt on there, everyone i found had it, figured just patch it.
got a buddy rebuildin one now and ran into the same thing
TX1GEN
Re: rebuild
Postby dazedandconfused » Fri Oct 12, 2012 9:51 am
They get really bad up here in the salt belt.
Re: rebuild
Postby TX1GEN » Fri Oct 12, 2012 12:20 pm
TX1GEN
Re: rebuild
Postby TX1GEN » Fri Oct 12, 2012 1:27 pm
TX1GEN
Re: rebuild
Postby tampabayBill » Fri Oct 12, 2012 1:32 pm
Really nice work ! Just painted mine an 09 Dodge color Deep Water Blue Pearl and it looks great.
Twins coming soon!
tampabayBill
Re: rebuild
Postby TX1GEN » Mon Oct 15, 2012 7:24 am
getting everything lined up and ready to start the interior
TX1GEN
Re: rebuild
Postby dazedandconfused » Mon Oct 15, 2012 7:35 am
Are you leaving it flat black?
Re: rebuild
Postby TX1GEN » Mon Oct 15, 2012 9:56 am
ya, im gonna keep it flat black, i may throw a red pinstripe down the side of it and do the tailgate letters in red as well
TX1GEN
Re: rebuild
Postby TX1GEN » Mon Oct 15, 2012 9:59 am
just threw in a fresh layer of hushmat, sound deadener, keep er nice and quiet
TX1GEN
