Pillar Gauge Pods
Pillar Gauge Pods
Postby 75Dodge » Sat Feb 23, 2008 10:48 am
Does anyone know where to find Pillar gauge pods for our trucks?
1989 D-250 LE Automatic 150hp at 55mph! 3200K Spring, tweaked pump, H1C/H1E hybrid.
75Dodge
Postby Philip » Sat Feb 23, 2008 10:59 am
Geno's garage has them.
There are two different mfg's of the pods for our trucks. One brand is autometer the other is propods. The autometers give a etter viewing angle.
Postby 75Dodge » Mon Feb 25, 2008 11:55 pm
Geno's definitely has them. But I checked Autometer and they just have stuff for 98 and up. What do you, or anybody else, run?
75Dodge
Postby KTA » Tue Feb 26, 2008 9:22 am
I have the autometer 2 gauge setup. It woks great if you have an LE trimmed truck.
Postby Philip » Tue Feb 26, 2008 9:32 am
I have the AutoMeter 2 gage pillar mount and the single gage steering column mount.
AutoMeter might only show 94 and up on the website. But I would give them a call and see if they have any for our trucks in stock.
I have seen and set in a truck with the ProPods that Geno's sells. I do not like the angle of the gages.
Postby 75Dodge » Tue Feb 26, 2008 1:00 pm
Good to know! Thanks! I will definitely call autometer.
75Dodge
Postby dpuckett » Wed Apr 02, 2008 6:13 pm
Autometer p/n's are 15198 for the 2gauge pod; 15199 for the single. Or I could have the numbers reversed, but that is the range you need to be in.
Will a single and double fit on our relatively short A-pillars? i was thinking of that, as I have an auto, and if I keep it, I'll have pyro, boost, tach, fuel pressure, and tranny temp.
Daniel
Postby nooblet » Wed Apr 02, 2008 6:41 pm
Auto Meter dual gauge pod part number 15198. I got mine from egauges.com their part number for it is ATM-15198. $29.90 from egauges.com.
Chris
nooblet
Postby 91dodgecummins12v » Mon Dec 22, 2008 5:11 pm
hey just wondering what gauges you went with (part #'s), there are more than one of the Autometer Phantom II guages... i dont know which one to choose, they all look the same to me, besides the different boost levels... thanks
also, does autometer make a 2-1/16" tachometer that would fit into the pillar? i wanted to do boost and tach seeing as though my truck doesnt have either.....
1991.5 Dodge Cummins LE, SC LB, 12 valve 5.9L, 4x4, Intercooled, 4 speed A518 Auto, Straight Piped, 5" MBRP Curved Stacks, 158,000 Miles.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>ALBERTA COAL ROLLERS<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
91dodgecummins12v
Postby mcarmaniac » Mon Dec 22, 2008 7:15 pm
ya I think its a Z gage or something I believe the part number is 2697
mcarmaniac
Postby peobryant » Sat Dec 27, 2008 1:25 pm
I would get a pyro before I got a tach. Boost, Pyro, Fuel Pressure, and Tranny Temp (for an auto) are the most important gauges. A tach is just a little something extra. 8)
Postby 91dodgecummins12v » Sat Dec 27, 2008 3:27 pm
True, but its also nice to see what exactly what its revving at.... i have never owned a vehicle without a tach so its just hard to get used to not having one is all.....
next payday i will be getting the a-pillar mount and gauges so we will see how that goes. thanks for the advice!! :)
91dodgecummins12v
