Resurrection of the dodges paint And back to stock power
Re: Resurrection of the dodges paint And back to stock power
Postby CumminsPower59 » Sun Jan 04, 2015 5:00 pm
Part of the part number stamped into the side of the pump.
Postby ellis93 » Mon Jan 05, 2015 5:55 pm
Ok I found out where the soggy power issue was....afc guide pin was stuck. Freed it up and it was a whole different truck way better/more powerful than it was before.....ever. My original pump must have been sucking butt for a long time. I'm going to actually back off the power screw :lol:
And the guide pin stuck again.....I have the throttle linkage pulled apart and the plug pulled to get at that pin. It's stiff as hell,that oring is some kind of hard in there. I'm letting it soak over night in some silicone spray.....I tried pb blaster first but it made things feel worse.
Anyone have a lube that worked for this little situation?
The pump still leaks fuel tho....still gonna pull it back off,but not till I gut a core pump to see what's inside.
Postby PToombs » Mon Jan 05, 2015 6:18 pm
ellis93 wrote:Anyone have a lube that worked for this little situation?
KY makes my pin slide real nice. :mrgreen:
Postby ellis93 » Mon Jan 05, 2015 6:27 pm
I like astroglide ;)
Seriously,I need to find something to free it up temporarily
Postby PToombs » Mon Jan 05, 2015 6:29 pm
LOL, you would! You been in Ohio again visiting? :lol:
Postby ellis93 » Mon Jan 05, 2015 6:41 pm
Good God :lol:
Postby CumminsPower59 » Tue Jan 06, 2015 11:38 am
Never had an issue, but clean it up real good and put a little heat on it. I haven't found anything on these pumps that a small hand impact driver or heat will loosen.
Postby PToombs » Tue Jan 06, 2015 6:09 pm
So you want him to heat the fuel pin and burn the o-ring off it? That will free it up all right! :lol:
Postby ellis93 » Fri Jan 16, 2015 7:19 am
Well the pin is staying stuck when it runs all the way in. I've managed to run the fuel pin down far enough for the truck no to smoke too bad while allowing the guide pin not to stick.....to bad.
180 miles later....pump is still leaking and the pin is still sticking. Can't wait to get the resealed pump on it and tuned.
Postby DMan1198 » Fri Jan 16, 2015 8:01 am
Isn't there a way to drill that hole and put a longer pin in?
Postby ellis93 » Fri Jan 16, 2015 3:48 pm
Don't know....I've seen a post about a longer on period. Seems to me you could just use the right diameter drill bit shank and do the same.
Postby DMan1198 » Fri Jan 16, 2015 8:57 pm
I Think Eric was talking about it. After that you can run a longer slide pin so you rule out the chance of overextending and causing a leak or some such
Postby PToombs » Sat Jan 17, 2015 5:33 pm
Take the top off and change the damn o-ring! Why do you want to change the pin when it's most likely a bad o-ring? Jeez, some days I think yo momma dropped yo on yo haid! :lol:
Postby ellis93 » Sat Jan 17, 2015 5:54 pm
I would but the gov shaft seal is leaking to....don't want to put too much time in Dickin with that when it's coming off anyhow ;)
Postby PToombs » Sat Jan 17, 2015 6:23 pm
Are you replacing it with the one you are rebuilding with a moron?
