1991 D O D G E letters
Postby jorez » Mon Mar 26, 2012 6:48 am
Is there anyplace, other than getting a new grill..to get the 5 little black letters that are attatched to the grill? My grill is fine, just missing the letters..like someone popped them out for some reason..no junkyard around me has any..so no luck there...
jorez
Re: 1991 D O D G E letters
Postby CUMMINSDODGEMAN3 » Mon Mar 26, 2012 6:58 am
I think my original grill has them on there still. apparently impossible to find cause i looked too for a new grill. PM me what you think theyre worth?
Team Green's old hauler 05 3500 CTD 4x4 6sp 8in rize industries lift, 37 Toyo M/T's, Smarty, Edge Att, AFE intake, ATS manifold Borg Warner turbo, 5in SS MBRP
90 W350 CTD SRW big pump, big turbo, lots of fuel, 47RH billet suncoast triple disc and 20's
93 D250 CTD ext cab pump work, POD's
CUMMINSDODGEMAN3
Postby BobS » Mon Mar 26, 2012 8:19 am
EACH letter, D O G E, had its own part number. The ones I have seen were mounted with the letter pins through the holes in the grille shell and were melted in place from behind. It was cheaper than using a slip nut from behind. Chrysler engineering probably saved five cents per truck by melting them in place.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby PJ 3 » Sat Mar 31, 2012 7:42 pm
The ones on my 92 were melted in. I sanded the melt of the back side and popped the letters out and stuck them on a new aftermarket grill with 3m two sided tape.
Pete
1992 W250
PJ 3
Postby Mark Nixon » Mon Apr 02, 2012 8:56 am
Last I checked with a dealer, there were still some new DODGE grille shells left, with the D-O-D-G-E letters on them.
Very spendy, though. :roll:
Emblem adhesive works nicely on the letters.
Grind the backs smooth, prep the surfaces with hot soapy water, followed by alcohol or lacquer thinner, then paste them on with the emblem adhesive.
Wait until the adhesive hardens, then carefully trim off any excess with a pen knife.
The OEM grilles actually have a slight depression behind each letter, but from 5 feet away, it's hard to see the difference between that and a repop grille, unless the letters are spaced wrong.
Postby ramtough1993 » Thu Apr 12, 2012 9:32 am
I took the letters of a busted up grill at a junk yard, they were melted in, so I took a dremel tool and ground the pegs smooth preped them and the grill with alcohol and used emblem adhesive and stuck em right on. They look totally factory.
1993 Dodge Power Ram 150 4x4, 5.2L Magnum, Automatic Transmission, Work Special Package, Currently mostly stock
ramtough1993
Postby KurtzN1 » Thu Apr 12, 2012 10:12 am
Sometimes they pop up on ebay, but it's not often that they do.
KurtzN1
Postby kbhblazer » Sat Apr 14, 2012 11:52 am
Why dont the come on reproductions
kbhblazer
Postby Mark Nixon » Sat Apr 14, 2012 12:11 pm
kbhblazer wrote:Why dont the come on reproductions
Copyright infringement.
