looking for cc or 4dr body
Postby Diezeldriver » Fri Nov 02, 2012 5:09 pm
Had a tree fall on my truck during Sandy this week, looking for a replacement body for it, preferably in the NE. Any help would be greatly appreciated.
92 W250 Club Cab, cut fuel pin, fuel screw turned up, M&H timing device, POD injectors, K&N filter, 4in exhaust from the DP back, 16cm turbine housing, Autometer Ultralite 2 guages, Suncoast 47RE transmission, Ruenel Bumpers, Best 1/4 14.51 @ 90mph.
96 2500 reg cab CTD: 60# valve springs, silverbullet, switch to lock, afc, 4k gov spring, no plate, 4in dp to 6 in stack
Diezeldriver
Re: looking for cc or 4dr body
Postby m880cummins » Fri Nov 02, 2012 5:37 pm
There are two solid looking crew cabs in the Washington area craigslist for $2000-$2500. That's a pretty good price IMO if the floors and rockers are solid. Don't count on the roof though. Mine I paid $1200 for and everything was spotless until I pulled the drip rail molding off. The steel driprail came off with the molding :| :shock: .
You can hack any front skin portion off a club cab and it will be the same and also the same for standard cab trucks BETWEEN 1972-1980 only.
Charlie
SUNY Maritime Class of 2017!
m880cummins
Postby BobS » Sat Nov 03, 2012 2:46 pm
NOT MINE!!! CONTACT THE SELLER DIRECT -- Location Caldwell OH??
93 5 speed ext cab dodge dually diesel - $2500 (caldwell)
http://wheeling.craigslist.org/cto/3383207664.html
FROM THERE:
i hav a 93 dodge diesel ext cab the motor has less than 100k on it starts right up no mater how cold it is its got no blow by the bad the trans is out but its a 5speed and it just needs the front bearing in the trans but its not a bad trucks call me for more info thanks my names corey and my number is 740 260 8817 txt or call sorry but pics wont load on here so txt for pics
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
