door swap
door swap
Postby Remps » Sun Nov 25, 2012 12:55 pm
My drivers side power window gave out a while back, and now my linkage broke on the back of the door handle, so it only opens from the inside. Can I take the power window door off my 86 parts truck and swap it onto my 90? Will the wiring harness hook right up, or would it need some modification?
Re: door swap
Postby simplysmn » Wed Nov 28, 2012 10:16 pm
Yes it will swap over 81to 93 is same body line and style
simplysmn
Re: door swap
Postby dazedandconfused » Thu Nov 29, 2012 5:54 am
I don't know if the wiring is the same but i doubt it.
Re: door swap
Postby simplysmn » Mon Feb 04, 2013 12:36 pm
well my 89 was the same as 93 so check the wires and go from there should be same
simplysmn
