How common is this?
How common is this?
Postby 93 W350 LE » Sun Jun 30, 2013 4:08 pm
So when I got my truck, you could touch the inner layer of the roof trough holes as big as your hand, on both forward roof corners.
My Dad had the truck repainted and supposedly this was repaird when the holes were much smaller. Was told this was common of these trucks. Really? I have personally owned several trucks through this body style, and never experienced this.
Any ideas?
Thanks.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
Re: How common is this?
Postby ellis93 » Sun Jun 30, 2013 7:45 pm
I don't know how common your issue is,but my truck is rusting from the inside out of the roof right along the rail. I've fixed it a time or two by welding the holes up but this winter the roof is coming off :/
Postby dazedandconfused » Mon Jul 01, 2013 3:22 am
Check the seem sealer in the drip rail. I'll bet the edge the windshield sets in is rotted as well. My old cab was like that. Water was getting in between the skins and rotted the bottom out.
Postby 93 W350 LE » Mon Jul 01, 2013 7:24 am
Started to try to stop it his weekend. Digging out the old sealer, digging out all the old rust I can get to in the roof, layed some metal mesh and fiberglass, now have to do some bondo and redo the seam sealer. All while driving daily in SWFla's rainy season, so rain everyday. UGH!
Any suggestions for repairing this, or is it just band aid until I find another cab?
93 W350 LE
Postby dazedandconfused » Mon Jul 01, 2013 7:33 am
I'd personally look for another cab if its as bad as you say it is.
Postby 93 W350 LE » Mon Jul 01, 2013 9:39 am
Yeah, I can lay an open hand in each side at the largest part. It involves both outboard marker light at their outside screw holes. The sad thing is the rest of the truck is solid.
Anyone know what a club cab is runnin these days?
Thanks.
Eric
93 W350 LE
Postby dazedandconfused » Mon Jul 01, 2013 9:45 am
Seen a few rust free ones from $800-1000 but they are out west.
Postby 93 W350 LE » Mon Jul 01, 2013 6:45 pm
I need to check with a friend back in Oklahoma who owns a Dodge/Chrysler salvage yard. Would like to do a swap to an old crew cab, with having 2 little ones it would be nice.
Eric
93 W350 LE
Postby 93 W350 LE » Thu Jul 11, 2013 8:53 am
So I gutted the drip rail of all the old seam sealer, wire wheeled it, got all the old rust out I could get to. Used aluminum grill grate to shape and applied bondo, reapplied seam sealer and sanded and primed. Looks pretty good, and the last few rains haven't soaked my floor or had water run down my pillars. Now to get new marker lights and refinish the rest of the roof.
Eric
93 W350 LE
