dually bed to SRW
dually bed to SRW
Postby TRACTJDS0428 » Sat Aug 16, 2014 6:25 pm
Ok not trying to bring up a beat to death subject. I have a rust free dually bed. I need a bed for my SRW W250 but dont really want to do a dual conversion. LMC has the repair panels for a SRW and I want to know if anypne has custom fit the repair panels to a dual bed for the correct wheel well size? I know the fender well itself will be taller on the inside. Just looking for cosmetics. Thoughts? Im a technician/fabicator and pretty good with body work. Not afraid of the challenge but would like to see pics if someone has already done it.
1993 Dodge W250, Cold Air, Borg Warner 60/68 turbo. 4" down pipe. 5x14 Injectors. Pump Mods. Airdogg II 165, Billet Fuel Tank Sump. ATS valve body, ATS converter, Pyro, Fuel pressure, Boost and Trany temp gauges. 72" T-Rex Products Long Bars. 285/75-16 Toyo Open Country M/T's. Western 9Ft MVP Ultra Mount V-Plow.
TRACTJDS0428
Re: dually bed to SRW
Postby dazedandconfused » Sat Aug 16, 2014 6:54 pm
Its no different then welding in patch panels.
Postby crossy » Thu Aug 28, 2014 1:14 pm
ANd you should be able to sell the fenders off of the bed to recoup the money- I have a friend in need too :-)
1990 D250, 5spd, 3.54, 35K miles,' Lomi '
1991 D250, 5spd, 3.54LS, fix-r-up toy, all stock,resto,'Pbob'
1992 D250, 5spd, 3.54LS,'CandyCane', almost daily driver
1992 W250,CC,auto,3.54LS,Picker
1990 D250,auto, 3.07, 'Doubleblue'
1973 Pinto w/ 13"cragars- ewww!
Sold 9 other 1st Gens that WE saved from death :-) and 3 that I couldn't save:-( - not counting gassers
crossy
Postby DIY Rooster » Sat Jan 31, 2015 3:03 pm
I am looking for the dually bed. Is yours still available? Or do you know where I can find one. I have a utility bed on my 92. Dually. Pls point in right direction.
DIY Rooster
