"Holes drilled in cab ceiling to combat roof rot"
Postby Begle1 » Sun Mar 31, 2019 1:28 pm
Anybody have pictures of holes drilled in their cab ceiling to combat roof rot/ rust from the inside out above the windshield?
I always hear it discussed as a "thing to do" but have never seen the end product.
If done clean then I imagine it'd be a good project.
Re: "Holes drilled in cab ceiling to combat roof rot"
Postby thrashingcows » Mon Apr 01, 2019 12:45 pm
The problem with the front header is there are 3 layers that come together and it's very prone to holing moisture. I personally use a long flexible extension sprayer for my Fluid-Film cans and then remove the visors and feed the sprayer in each side and give it a good coating.
thrashingcows
Postby bensol64 » Thu May 30, 2019 12:10 am
I think using Fluid Film is a good idea. I used this product on underside and frame of my truck.
bensol64
Postby ellis93 » Thu May 30, 2019 5:19 pm
Begle1 wrote:Anybody have pictures of holes drilled in their cab ceiling to combat roof rot/ rust from the inside out above the windshield?
I’m having to revisit my roof rust. I’m pondering on the same thing. Hole saw time doesn’t sound like much fun.
