First test drives with 5.9 and zf-6 with ford stock clutch pp and friction disk.
This thing has the stock ford hydraulic clutch master/slave to push the fork.
is there a way to verify that the fork is all the way released when I release the clutch pedal. ?
Is there a way to do it by taking out the slave and measureing the distance from the hole to the fork ? and comparing
that with the stick-out on the slave ?
Tim
