1979 Power Wagon CTD Build
Postby 79Powerwagon » Thu Jan 07, 2016 9:07 am
Also on RCC,
Build I've been working on the last few months. 79 power wagon, 93 cummins/518 transplant.
79Powerwagon
Re: 1979 Power Wagon CTD Build
Postby spencerdiesel » Thu Jan 07, 2016 7:25 pm
I'd drive it
H1C/18
Muffler delete
spencerdiesel
Postby thrashingcows » Fri Jan 08, 2016 11:41 am
I'm only getting one side of the big pics. :(
thrashingcows
Postby dazedandconfused » Fri Jan 08, 2016 12:14 pm
Looking good. What are the specs on it? Leaving the Dana 44 up front?
Postby 79Powerwagon » Fri Jan 08, 2016 12:28 pm
Not sure what's going on with pics, when I posted it it was fine.
As far as specs....
Got the 79 locally , had been sitting a long time outside. Someone tried to mimick a Macho paintjob. Sort of attracted me to the truck. It's unique.
Waiting on swapping the d60 in, it needs a reseal and u joints.
The 93 was completely rotted out, unsafe to drive. So, in the Cummins went.
Rebuilt the floors on the 79, soundproofed and bedlined. Doors from the 93 for now. 93 core support modified slightly to utilize 79 grille.
Have a HE351 waiting to go on. Down the line I have a s400 based turbo for compounds. Going to need fuel.
Sort of a rat truck...with some torque 8)
79Powerwagon
Postby 79Powerwagon » Fri Jan 08, 2016 12:35 pm
Donor truck
79Powerwagon
Postby 79Powerwagon » Sun Jan 10, 2016 3:17 pm
New fuel cell.
79Powerwagon
Postby PToombs » Sun Jan 10, 2016 4:37 pm
I hope that copper tubing is a temporary thing. Copper reacts with the diesel and will form a scale that will plug the tubing after a while. I've seen it, but don't know how long it takes, maybe a few years.
Postby 79Powerwagon » Sun Jan 10, 2016 4:48 pm
The copper ends at the bed and meets with rubber fuel line. I believe a reaction only happens with biodiesel/wvo, etc...
Diesel watercraft commonly use copper line.
I'll keep an eye on it, though.
79Powerwagon
Postby 79Powerwagon » Mon Feb 01, 2016 10:12 am
79Powerwagon
Postby thrashingcows » Mon Feb 01, 2016 2:16 pm
Looking good! Wish I could see more of the pics..... :( But the vid was good!
thrashingcows
Postby 79Powerwagon » Fri Feb 05, 2016 9:23 am
Stuck an additional leaf in front, and the D60
79Powerwagon
Postby 79Powerwagon » Wed Feb 24, 2016 9:55 am
79Powerwagon
Postby 79Powerwagon » Mon Feb 29, 2016 11:17 am
I don't have access to the parts for sale section yet, but I am in need of some parts if anyone has them. I would like to buy used if possible, or if anyone has some new parts laying around. :mrgreen:
He351cw cartidge or center housing &turbine wheel/shaft
6 60lb valve springs
Arp head studs or upgraded bolts
Gauges, egt, boost, fuel pressure or trans temp
5X14 injectors or something close
Water seperator
Thank you
79Powerwagon
Postby justin.loehlein » Mon Feb 29, 2016 5:41 pm
Nice. What are your plans for the truck? Just for fun?
1990 D250, 5 speed
1993 W350 waiting to be restored
justin.loehlein
