ideas to damp out single mass flywheel noise ?
Postby jethro » Sun May 01, 2016 11:39 pm
Is there any clever ways to help damp out manual trans noise after conversion from dual mass to single mass fly-wheel ?
(ford zf-6 and 12 valve cummins-)
From what i have read the ZF trannys dont tollerate changes to the oil viscosity too much..... and that was the
only thing I could think of .......
Tim
jethro
Re: ideas to damp out single mass flywheel noise ?
Postby BC847 » Mon May 02, 2016 4:28 pm
I've heard the Fluidamper (or the like) is good for fixing that. I've no experience with that though.
Postby jethro » Sat May 07, 2016 12:07 am
Thanks BC-
Do mean that there is an aftermarket damper that has more damping capacity ? (more going on)
than the stock ones.....
I have seen some for 500 $ but they dont say much about what they are or if they are different----
Tim
jethro
Postby PToombs » Sat May 07, 2016 5:55 pm
The Fluidamper that BC mentioned is an aftermarket high end damper. I've read that it cancels out vibrations really well, and yes, it costs close to $500 IIRC. Genos Garage has them, but I'm sure they are in Summit, E-Bay and all over.
