D4H Dozer
All of 'em
Re: D4H Dozer
Postby collegekid » Thu Nov 03, 2011 7:59 pm
Fair enough, i going togo look at it again and give it another close inspection and hope it all works out, if not, Ill let you know
collegekid
Re: D4H Dozer
Postby diesel freak01 » Fri Nov 04, 2011 5:20 am
If you can get me the serial number from the machine i can get you any schematic (hyd or electrical). I work for a Cat dealer in WV so if i can be any help just lep me know. The other comments are correct i dont think it got to awful hot. Depending on availability you should be able to take every pump and valve apart and rebuild it with no problems and that machine is common enough that you shouldnt have any problems. As far as used parts go, our dealership has a used parts division so thats a help.
Depending on what price you are getting it for, that winch is worth easily $12k to $14k, just bought one similar for a D5C. those tracks seem to be a little odd, so they may be a high dollar item for a specialty. The undercarriage looks to be in pretty good shape from what i can tell. Sprocket segments look to have a good bit of life left. If you have the extra cash I would jump all over it. If nothing else just take it home and put it up on Equipment Trader or the like. Im sure there is money to be made on it.
1993 d350 ctd drw 2wd auto
diesel freak01
Re: D4H Dozer
Postby collegekid » Wed Nov 09, 2011 8:05 pm
I just purchased the dozer, it'll be delivered in a week or so (as soon as I make room in the shop) The winch in the pictures will be for sale, figured I would ask anyone on here if they were interested before I put it on an equipment site, or ebay.....The specs are listed below:
Weight: 1965 lbs
Length: 40.25"
Case Width: 39.5"
Flange Diameter: 17.5"
Drum Width: 9.5"
Cable Size: .75" (has cable and hook on it, not sure of the length yet)
Oil Capacity: 12.5 gallons
Im open to all offers, or trades, in particuar looking for a large backhoe, hydraulic dump trailer, excavator, etc
collegekid
Re: D4H Dozer
Postby Hansen01 » Wed Nov 09, 2011 8:10 pm
Put in on the front of your truck ;) never again would you need to be pulled out :lol:
Under construction...
Hansen01
Re: D4H Dozer
Postby collegekid » Wed Nov 09, 2011 8:13 pm
Idk what its rated to pull, but the dozer weighs in right around 30K, so Im thinking 60Kish.....def a conversation piece
collegekid
Re: D4H Dozer
Postby diesel freak01 » Thu Nov 10, 2011 6:08 am
Does the winch have a serial number or brand name on it?
diesel freak01
Re: D4H Dozer
Postby collegekid » Thu Nov 10, 2011 2:31 pm
yea, but Ill have to go back out and see what it has on it, from the pictures Ive seen I think they are calling it a Cat54 Winch? but I will double check on that and get a serial number
collegekid
Re: D4H Dozer
Postby collegekid » Sun Nov 20, 2011 7:22 pm
The winch is a Cat54 PS
collegekid
Return to Other diesels
