Steering issues on duramax
All of 'em
Postby 89workhorse » Fri Feb 17, 2012 2:09 pm
Hey guys, my 01 2wd duramax is having handling issues, the steering colum wont lock, & while driving has a lot of slop back & forth, & gets alittle hard to steer, could this be in the colum/ steering shaft or am I over looking the suspension, any ideas would help thanks
1989 D250 4wd, Maxed ve, denny t stage 2, 366 spring, 60mm turbo upgrade, 4" straight pipe, ddp stage 3 injectors, glow shift guages, 180xxx miles
2001 2500HD 2wd, all stock (not for long) lb7 6.6 duramax, 230xxx miles
89workhorse
Re: Steering issues on duramax
Postby dazedandconfused » Fri Feb 17, 2012 2:28 pm
Check or replace idler arm, and rest of steering parts. They need the idler replaced every 80 -100k miles.
Postby PToombs » Fri Feb 17, 2012 6:01 pm
Park the POS and drive the Dodge! ;)
Postby 89workhorse » Fri Feb 17, 2012 6:05 pm
Wish I could man the dodge is in missouri & im in california in the marines right now
89workhorse
Return to Other diesels
