he351cw arrived in the mail now what......
Postby 78fordf150ranger » Thu Sep 13, 2012 11:12 am
Okay just got my he351cw in the mail,now what injectors?
Truck is a 1993 reg cab long box
Auto trans
4x4
Denny-t stage 2
K and
Straight piped to 5 in stack
3200 gov spring
Pump tweaks star gears bottomed
My elevation 330m above sea level I will not be towing unless it 3500lbs
What injectors.would you guys suggest smoke isn't a huge issue
78fordf150ranger
Re: he351cw arrived in the mail now what......
Postby tampabayBill » Thu Sep 13, 2012 12:07 pm
What do you plan to do with your truck ? I would guess 5x12, 5x13, 5x14 would do well with your current sig.
Twins coming soon!
tampabayBill
Postby 78fordf150ranger » Thu Sep 13, 2012 12:14 pm
Daily driver/play toy
78fordf150ranger
Postby BILTIT » Thu Sep 13, 2012 12:19 pm
I would install the turbo and try it out first :P
I have a set of 5x14's coming for my setup, i think its on the upper end of what i want because i do tow and don't like smoke.
Derek B.
BILTIT
Postby cmann250 » Thu Sep 13, 2012 12:21 pm
It's cliche, but put money in the transmission. Power and torque are cool to have, but getting it to the ground efficiently is what will make the most difference to the seat-of-the-pants dyno
Postby tampabayBill » Fri Sep 14, 2012 6:50 am
X2, a TransGo valvebody kit and a good convertor make a real difference.
Twins coming soon!
tampabayBill
Postby bmoeller » Sat Sep 15, 2012 5:06 pm
cmann250 wrote:It's cliche, but put money in the transmission. Power and torque are cool to have, but getting it to the ground efficiently is what will make the most difference to the seat-of-the-pants dyno
Not only "seat of the pants", but in real numbers too. A non-lock up t/c, and trying to slam more power through it will be a waste.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
