by 12vsuburban » Fri Mar 01, 2013 6:10 pm
I have a '92 with minor mods. internally stock, WH1C from a '94, still stock downpipe, but 4" from there on out. Bigass airfilter, previous owner had put a brand new injection pump on it and just turned the fuel screw to the collar. looks like smoke screw has been turned a bit, no clue on star wheel. I just put on the WH1C this week and made a huge improvement , especially down low from the 21cm stock turbo. I dont have a EGT yet but boost was at 24-25psi max with the new turbo. The wastegate is not hooked up. SO, tonight I decided to look at the fuel pin as I didnt know what position it was in. the dot was toward the block, so fairly stockish. I turned it about 90deg clockwise so its facing rearwards now and the steep side of the concentric toward the front. after doing this it will hit about 10psi and flatten out. Seems maybe a hair more responsive right off idle before it flattens out. I took off the cover again to check all was ok, and looks fine. the pin in the front stays pushed in when i pull up the fuel pin...should it do this I guess? what pushed it out against the fuel pin? I could NOT see any line where the pin was riding on the fuel pin as I could when I took it out...
'92 one ton,auto, 250k,flatbed,original paint: WH1C turbo from a '94(12/56), BHAF, 4" exh from firewall back, fuel screw to the collar, turned stock pin
