by RCCUMMINS89 » Wed Apr 03, 2013 7:58 am
Same reason our engines don't rattle as much in the high rpms. Even though it is actually further advanced..... it really isn't in the grand scheme of things.
But what do you consider a "hot rod ve". Are there internal things that you are doing to these pumps (w/the exceptions of the couple new tings) that let's say me, BC, or a lot of the other guys have done? Also though, I've never blown a head gasket at idle or low rpm. I've always lifted my head at wot at 45 psi and above 2000rpms.
Now saying that, I'm not disagreeing that it cant be done. But it's def. hard to get over 400 while keeping the cylinder pressures down with a ve, especially a single turbo.
89 RC on shortened 92 diesel frame - NV4500 w/dual disc/4.10s on 37s. - Self built pump, "hot screw", lots of timing, True high volume low pressure lift pump, 62fmw/68/.7gated, 77lpm SAC Inj., Studs/O-rings,- 423/1220 Mustang - 11/16/2013
http://www.TheHungryDiesel.com full line dealer, if you don't see it please ask.
