dunes450r wrote:the very small (9cm2) exhaust housing on the 351 is a known choke point. you hear of people complaining that a 12cm hx housing is small and can cause high egts, a 9 is even tighter. i know lots of people on here swear by them on here, but I still think the housing is just a little too small, especially when combined with bigger sticks and towing. they flow lots of air, but they have high drive pressure to do it.
RC said he had 30psi of boost to maintain 50mph towing 10k with a 351
I towed 8.3k at 60mph with an H1c and 12cm exhaust housing and only had 7-8psi
lots of fuel, and lots of weight is just a little too much for the small exhaust housing IMO. i'm sure people will disagree and say i'm wrong but oh well, my opinion
i think you need to look into a bigger turbo if you want to tow with full power. something like an hx40 would probly work and be cheap, or start looking into an s300g or similar
BILTIT wrote:dunes450r wrote:the very small (9cm2) exhaust housing on the 351 is a known choke point. you hear of people complaining that a 12cm hx housing is small and can cause high egts, a 9 is even tighter. i know lots of people on here swear by them on here, but I still think the housing is just a little too small, especially when combined with bigger sticks and towing. they flow lots of air, but they have high drive pressure to do it.
The above bolded is not true.
I have towed 10k camper at 60-70mph with only 8psi, no problem. The 351 EH is not as restrictive as you think (at our power levels anyways).
Mind you i am running stock injectors but it comes down to pump tuning which controls egt's the most. I dont like smoke so i dont waste fuel by pouring it out whenever i hit the throttle. I can pull that same camper setup up a steep grade at 1230egts wot, 40psi and accelerate the whole way and be 75+mph at the top.
BILTIT wrote:You have to keep in mind the 9cm is UNDIVIDED VS a DIVIDED 12cm, so they are virtually the same size housings. The 9/12cm works wonders with a std trans, the autos seem to like a 14/16 better.
RCCUMMINS89 wrote:An he351cw has a non divided 9cm housing.... non divided housings out flow a divided housing of comparable size. A 9cm housing on the 351cw flows in comparison about the same as a divided 12.
