proper timing
proper timing
Postby ellis93 » Sat Apr 06, 2013 6:12 pm
Considering my "issues" in this tread
viewtopic.php?f=1&t=14053&p=125010#p125010
What should I need for timing for these flow honed 5x10 injectors that flow at 45lpm,I dont know what that turns them into as far as size.
Re: proper timing
Postby RCCUMMINS89 » Sat Apr 06, 2013 7:11 pm
If you had a bone stock truck that you installed these nozzles in, I'd say 3/16" to a 1/4" bump..... So in your case being skipped a tooth, advance it 1/16" to 1/8" inch from being retarded all the way.
That's my advice and my tuning expertise being blind and not physically seeing how the truck reacts.
edit- these are flowing the same as a non i/c nozzle..... so try 1.45mm (I forgot you're getting a timing tool)
Re: proper timing
Postby ellis93 » Sat Apr 06, 2013 7:19 pm
That's where it's at now,lol. I'm going to figure this out....even if it kills me or I'm bald from pulling out my hair with my hands :lol:
Re: proper timing
Postby RCCUMMINS89 » Sat Apr 06, 2013 7:31 pm
When you get the timing tool let's see where it actually shows up at.
Re: proper timing
Postby ellis93 » Sat Apr 06, 2013 7:56 pm
RCCUMMINS89 wrote:When you get the timing tool let's see where it actually shows up at.
It most definitely will be deferent than where it is now,thing has got to advance or something. If you start it up cold its really cranky
Re: proper timing
Postby RCCUMMINS89 » Sat Apr 06, 2013 8:17 pm
Usually cranky when cold means it's too far advanced. Now that you are running smaller injectors that would be more noticeable..... in my experience anyways.
For example my truck was very very very hard to start when it was below 30 over night, but with these bigger injectors at the same static setting it fires up in half a turn like it did stock (did last night anyways and it got down below freezing)
Re: proper timing
Postby ellis93 » Sat Apr 06, 2013 8:26 pm
Eeeh....long ago,in low temps and the truck stock...I had to advance it because of the same thing. I'll go against instinct and retard it first.
Re: proper timing
Postby RCCUMMINS89 » Sat Apr 06, 2013 8:33 pm
Well....... it could be either way really.
