What PSI lift pump do i need?
Postby rollieD250 » Sat Dec 13, 2014 10:28 am
(I did search for this)
Getting ready to order a 2nd gen lift pump from the hungry diesel and i have 2 options as im sure most of you guys know 15 or 18psi
Going to be running a 57/65/14, 5x12's, timing spacer, fuel screw, pin and 3200 spring in the near future
Thanks alot guys
1992 D250
THD fuel pin, 3200 spring, 57/65/14, timing spacer, 3pc manifold, piston lift pump, ASA intake
rollieD250
Re: What PSI lift pump do i need?
Postby AHineman » Sat Dec 13, 2014 10:36 am
Either one would be fine. I personally would go to the higher side, but 15 would keep up with that setup easily. It's not a bad idea to run bigger line from the tank up as well if more power is in your future.
Postby 1992gen1_fan » Sat Dec 13, 2014 11:04 am
If you go with the higher psi pump its recommended to loctite the front seal in the IP especially if its an older IP.
1992gen1_fan
Postby AHineman » Sat Dec 13, 2014 11:32 am
Anything you change from stock is obviously at your own risk, but 18 or 20 psi wouldn't scare me on a stock front seal.
Postby rollieD250 » Sat Dec 13, 2014 11:56 am
Thanks guys i think im going to go with the 15psi for now should be able to make 300hp with it
1992 D250
rollieD250
Postby RCCUMMINS89 » Sat Dec 13, 2014 6:49 pm
The 15 psi will supply pretty much any setup. Unless one has very large injectors. Teh 15 maintains good pressure with my 5x17.
