60mm comp upgrade
60mm comp upgrade
Postby 92 D/UNIT » Mon Feb 19, 2007 7:26 pm
last week saw a guy on ebay selling compressor wheels, but he is no longer there, checked high tech for a stage III and they were out of stock, does anybody know were i can locate a 60mm comp wheel for a h1c?
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby DLittle » Mon Feb 19, 2007 8:01 pm
Try these guys. this is where I got mine and they were less $$$ then HTT
http://www.gdsdieselparts.com/
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby 92 D/UNIT » Mon Feb 19, 2007 8:17 pm
thanks Dana, wish they had prices listed, ill have to give em a call tomorrow. are you running a 60mm comp wheel in your truck?
388/886
92 D/UNIT
Postby DLittle » Mon Feb 19, 2007 9:13 pm
Yep :D :D and it sounds good too.
Dana
DLittle
Postby gman07 » Tue Feb 20, 2007 6:43 pm
Speaking of the sound...
http://media.putfile.com/Stage-IV
1992.5 W250 pump tweaked, straight pipe, gauges, 3200 Gov. spring, AFC lever partially ground, timed at 1/8", Fuel pin ground, BHAF, HTT Stage IV H1C/E 60/12wg (ported), Transgo shift kit, KDP clothes-hangered, 202,000 miles - 36psi, 1250°
gman07
Postby 92 D/UNIT » Tue Feb 20, 2007 9:48 pm
looking forward to hearing that in my truck.
Dana you were right about the price, a lot cheaper than HTT, 178.00 fOr the housing and wheel 8) 8) 8)
388/886
92 D/UNIT
Postby DLittle » Tue Feb 20, 2007 10:11 pm
That's what I paid 6months ago. They didn't raise their prices with the new year like some companys.
Dana
DLittle
Postby 92 D/UNIT » Tue Feb 20, 2007 10:15 pm
they were very nice to do business with, thanks for the tip, anyways its in the mail should have it by friday :D :D
388/886
92 D/UNIT
Postby Falcon » Thu Feb 22, 2007 10:50 am
Called them today. with what I want to do, I can build a hybred HX40 out of my parts and a few new ones. Looks like I be giving these guys a call when I'm ready.
Greg
Greg
Graham, Washington
"FIRST REAL TRUCK ENGINE...
LAST REAL TRUCK!!!
93 ex cab 4x4, Hybred 35/40,4" exaust all the way,pump turned alittle,DDP Stage III's, 366 spring,DDP fuel pin,AFE first gen air intake,pyro and boost gauges
Falcon
Postby rlyons » Thu Feb 22, 2007 8:15 pm
gman07 wrote:Speaking of the sound...
That's what mine sounds like with the ASA intake tube connected. :lol:
92 D250 Club Cab 4X2, 5 speed, ASA Modifieds Intake, Jannetty Racing Team Exaust System, Tweaked Pump, 3200 RPM Governor Spring, HTT Stage III Turbo w/16cm2 , Pyro/Boost/Tach Guages, Power Wagon Injectors, KDP Tabbed, Borgeson Steering Shaft.
rlyons
Postby TOMTOM » Thu Feb 22, 2007 8:45 pm
Falcon wrote:http://www.gdsdieselparts.com/
Greg
How mutch did they say? What parts would they use that were yours? ie hic or hx35w?
TOMMY
93 CLUB CAB LE SHORT BED 209,000 MILES AUTO/OD 3.54 GEARS 4" TURBO BACK EX NO MUFFLER P7100 PUMP MODS B/D INJECTORS 13.55@99 MPH 440HP 967TQ ON #2 ONLY. PSD INTERCOOLER,BD SUPER B TURBO)47RE FULL MAN SUNCOAST TRIPLE DISC
TOMTOM
Postby Greenleaf » Fri Feb 23, 2007 3:45 am
I upgraded to the PDR 58mm comp wheel and it did nothing for me. So, I them upgraded to the HTT stage III Hi-Flow 60 and it did nothing. I see 1500° easily with inner pump modifications/ 12mm hydraulic head/POD injectors and modified intake/exhaust manifold/full four inch exhaust etc.etc.
Greenleaf
tech specialist/mod
Postby KTA » Fri Feb 23, 2007 6:21 am
Greenleaf put a 40 on there that will help the egt's. I went from 1500 to 1300 on my trailer puller going from the 18cm h1c to the 16cm hx40, and it doesnt have any more lag.
Postby Greenleaf » Fri Feb 23, 2007 9:40 am
Thanks. I do appreciate your insite. I am, or was, under the assumption that becasue the 35/40 share the same turbine and shaft that I do, now have, a full 40 with the upgrade to the hi-flow/machine-cut 60mm comp wheel.....
I don't tow so the really high EGT's don't hinder me unless I perform a full-out run on the Interstate :shock: Would like to lower the temps a bit. I'm not too excited about reworking the air to air with a bigger Ford unit. I seem to enjoy holding down my recliner more than I used to. :wink:
I may get excited and install a smaller turbine housing to see if the faster turbine speed will move more air....... I use the 21cm now.
Greenleaf
tech specialist/mod
Postby KTA » Fri Feb 23, 2007 12:52 pm
That is incorrect. A typical hx35 has a 57mm exducer turbine, the Hx40 is 65mm exducer. The bigger wheel of the 40 slows it down a bit because of the extra weight and rotational inertia. It does however make more turbine power, so it can make the same boost with less back pressure so it runs cooler. Compared to your 21cm hsg I think you might actually notice an improvment in driveability(less lag) with the 16cm Hx40. The trick is to find a super 40 as they run 50-100deg cooler than a regular 40 because of better wheel designs.
Users browsing this forum: No registered users and 73 guests
