cheap monster turned money pit ;)
Postby motorwood » Sat Jul 10, 2010 8:11 am
I've owned the "War Wagon" a '92 350 4x4 since '95. Have allways had the fuel screw turned in pretty far but lately wanted to try some pulling in the stock class. Hood Stack, AFC lever gone, fuel screw maxed, throttle indexed and 354 spring(clipped 2 coils). Oh my, this thing is wicked. I've never heard of way past 30lbs on a stock 21cm turbo. I dont think my clutch will last though. I dont have anything for the chipped Duramaxes but I'm gonna have some fun and be the only one rollin' coal through the hood!
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857 :( 13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
motorwood
Re: Holy Crap.....created a monster
Postby motorwood » Sat Jul 10, 2010 8:13 am
I almost forgot, thank you to all that have gone before me and given me all these great ideas!
motorwood
Postby oldestof11 » Sat Jul 10, 2010 8:22 am
How did you spool that thing?!?!?!
I cannot wait till I get 2 stock steels to put on some Goodyear MT's for some 2wd pulls!
Postby motorwood » Mon Jul 12, 2010 8:43 pm
I'm not sure, but I have some ideas. First I'm fortunate to have a pump that allows the fuel screw all the way to the o-ring with no hint of runaway. Next it's a 1 ton which I think has a different compressor, not completely sure. Lastly that 5" hood stack has zero back-pressure. I'm guessing all this contributes to 35lbs out of a stock 21cm turbo. I have a 4200 rpm spring but it only carries that high boost from about 1700-2000 or so. O, and it puts a flame out the stack at night way cool. Lots of smiles for me!
motorwood
Postby delinquent » Mon Jul 12, 2010 9:31 pm
We need Video's
delinquent
Postby motorwood » Tue Jul 13, 2010 5:46 am
I cant even get a picture to load, says the files are "too large" But yes video of the flame would be cool!
motorwood
Postby onemoparnut » Wed Jul 21, 2010 1:41 pm
If you can turn the fuel screw all the way in and it dosent run away then that means you need a longer screw. Mine was the same way I added about 3/16" of weld on the end shaped it with a grinder then I found the runaway. You will get a bit more fuel if you do this.
onemoparnut
Postby JBradley500 » Wed Jul 21, 2010 3:41 pm
onemoparnut wrote:If you can turn the fuel screw all the way in and it dosent run away then that means you need a longer screw. Mine was the same way I added about 3/16" of weld on the end shaped it with a grinder then I found the runaway. You will get a bit more fuel if you do this.
hmm i always have this in the back of my mind.... does anyone else have an opinion on this ?
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500
Postby diesel freak01 » Thu Jul 22, 2010 4:42 am
if i remember correctly you can also purchase a longer screw from bosch or cummins that does the same thing, a few ppl are lucky enough to not have runaway and have done this to get more fuel.
1993 d350 ctd drw 2wd auto
diesel freak01
Postby motorwood » Thu Jul 22, 2010 8:12 pm
Gonna pull it Saturday night! Gonna try 2nd low ont he Getrag and 3.54's any thoughts?
http://www.facebook.com/album.php?aid=2 ... 3b5969fff8
motorwood
Postby motorwood » Sun Jul 25, 2010 7:16 am
Pull was disappointing, clutch slipped, but at least my truck came back home in one piece and is still usable.
motorwood
Postby motorwood » Sat Apr 23, 2011 8:20 am
A lot has happened since I last posted. I pulled the truck 6 times finishing 2nd to last at every pull, which was my goal for the first year. Post season brought POD's and a 60mm compressor(still stock 21cm exhaust), which netted me 379/848 on the dyno. That was the "well enough" I couldnt leave alone. Next came studs, valve springs, 14mm h/r, A1000, and 6x.016 Buddhas. I guess thats it. That netted me a siezed VE. A new VE from a very low hp application(2mm camplate and a less that optimal fulcrum lever) with another 14mm added gave me a disapointing 293/732 with no power above 2000 rpm's. I found a used 2.8 camplate, put it in, maxed the fuel and now have 50psi boost, a strong pull, and very hot egt's. Gonna check the dynamic timing, and dyno it again 7 May, hoping for a solid 400hp.
motorwood
Re: cheap monster turned money pit ;)
Postby dazedandconfused » Sat Apr 23, 2011 8:52 am
You need a better turbo. Hope you do good though
Postby ciamcoop » Wed Apr 27, 2011 3:21 am
I never figured a just a 60mm compressor could do 380 HP or that the shaft hasn't broken at 50 psi. Hope you get it dialed in and ready to pull.
'93 W250LE 4x4 club cab, getrag, denny t, 366 spring, 181/210 cam, bored. 020, KDP, 5x.014's, piston pump, 4" tbe, cold air, 255/85/16s, 3.54's one wheeler peeler
ciamcoop
Postby 1990 » Wed Apr 27, 2011 7:53 am
Keep us updated.
2012 Subaru WRX TP Stage 1 DD
Users browsing this forum: No registered users and 69 guests
