update... still no injectors, completely ruined my plans for the truck this summer.
pulling tomorrow, sat and sunday.
made a new fuel system yesterday, 5/8 (1/2 ID) air line for the feed, through a separator and a filter, 45 gal tank mounted in the bed, 1/2 return (3/8 ID) re-tapped the head of my piston pump for 3/8 pipe, while I was at it found the screen before the lift pump plugged (woops) gained 10 psi at idle from just cleaning out that screen filter.
truck runs better, more midrange power, less haze? don't know why but its a noticeable drip in part throttle haze. She is dead even with my buddies commonrail (stock turbo, 60% over CP3, 100horse over injectors, smarty set on kill) I'd like to dyno it before the injectors to see if I'm at 400 hp with the stock injectors. he only weighs in at 7000lbs, so i figure his HP is close to mine, id imagine he is easily 400
yes the truck is a mess... this may be the last season for this truck, may do a frame off build this winter.
![Image](http://i630.photobucket.com/albums/uu29/ahale2772/C9D9DCB0-B417-4E28-89E9-1EABA05215C6-99-0000000E90372A59.jpg)
and yes... there would be a lot less tubing here if I had used 90's, but decided not to for flow, the straight fittings do well, filter bleed themselves all the way to the lift pump, in essence the liftpump is gravity fed
![Image](http://i630.photobucket.com/albums/uu29/ahale2772/E7F53B18-F555-49BC-B7DC-53138AE077E5-99-0000000E9F46299E.jpg)
