Dual feed VE
Postby cummins king » Mon Nov 19, 2007 8:39 pm
hey mr ford you said somewere on a post that you nwere doing your cam plate or rollercam or somthing like that what is it exacly that your doing and why and what do you think youl gain out of it
93 4X4 auto
cummins king
Postby ford69557ci » Mon Nov 19, 2007 9:41 pm
i am having a higher lift cam plate made for the ip. its kinda the same idea as a higher lift longer duration cam in a 7100 pump. the higher lift will increase fuelin and the longer duration will not only quicken the amount of fuel it should add more fuel over a given point of rotation. this is not for sure but i am just hopin
ford69557ci
Postby Begle1 » Mon Nov 19, 2007 9:44 pm
So where is the "cam plate"? Inside of the pump?
Postby ford69557ci » Mon Nov 19, 2007 10:05 pm
yes it is the round thing with six bumps on it that the rollers ride on and in turn force the rotor in and out to make high pressure
ford69557ci
Postby KTA » Tue Nov 20, 2007 9:29 am
The vp 44 is a radial pump and it has 3 pumping elements. The VE is an axial pump and only has one pumping element. By design the VP can generate more pressure than the VE, so that is the reason they use it as more pressure means better atomization and more power. That is why everything is common rail now and they make tons of power and burn clean, they run LOTS of pressure!!
Postby ford69557ci » Tue Nov 20, 2007 5:15 pm
yeah but they sound like a tdi volkswagen :jumpsmile: I think i will stay with the good ole low pressure manual injected engines. it seems like the p pump guys are still makin way more power than the common railers and it seems like the common rails tend to run alot higher egt??
ford69557ci
Postby cummins king » Mon Nov 26, 2007 8:08 pm
i dont know if this was said some were else but can you get the cace presure from the fuel shot off, i cant see y not it would save me from drilling a hole i the what u ma call it, oh and what how may psi gage will i need
93 4X4 auto
cummins king
Postby ford69557ci » Mon Nov 26, 2007 10:30 pm
i thought about that but i am goin to try and feed fuel there so i think a good place would be on the pump top cover
ford69557ci
Postby DTanklage » Mon Nov 26, 2007 10:57 pm
0-300 psi for what i was suggesting
0-200 for a stock set up
DTanklage
Postby DTanklage » Mon Nov 26, 2007 11:44 pm
oh, unless you are aaron...
then 0-1000
lol
DTanklage
Postby dpuckett » Tue Nov 27, 2007 5:30 pm
Interesting thread, with lots of good ideas.
Don, let me know where you tap for the case pressure gauge. I may use one in the future, if for no more than MPG enhancement (which at $3.30/gal, would pay for the gauge in no time).
KTA- I, too, remember when Piers, et al, said 300hp in a rotary pump was undoable without reliability issues. Or lots of smoke and EGT. The HX40 and H2E were THE ticket in hot rod P-pump engines (350-400hp), and even then you had lag issues and bottom end smoke. It was said the VE could not move enough fuel to even spool it :o My, how times have changed.
MEby how much you asking for your pickup, and when are you finishing school?
Daniel
Postby ford69557ci » Tue Nov 27, 2007 5:35 pm
don i think 1000 psi would make a nice pump grenade i would imagin that 300 would be hard to see without some serious vane pump mods or elimation and one killer gear driven fuel supply pump.
ford69557ci
Postby meby » Tue Nov 27, 2007 7:16 pm
I just sold the truck this morning. Some guy from Iowa gave me $8100. for the privledge of taking it home. I will start school on jan. 10 and the plan is to go for a four year degree. :D
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby DTanklage » Tue Nov 27, 2007 10:51 pm
daniel, anywheres there is room
right above the ksb? just use the return and dont tap the case at all? there are a few options
aaron, yea, i was kiddin about the 1000, but with you and your crazy ideas who knows?
DTanklage
Postby JD730 » Wed Nov 28, 2007 4:56 am
I modified the return banjo bolt, my own custom tapped banjo bolt if you will.
Mike
The "Rattle Box"
JD730
