Also guessing feeding through the shutoff solenoid would be better for a part-time secondary fuel feed, and at least 250-300 psi case pressure could be maintained at wot with the pump I mentioned earlier, regardless of bleed off from the return and case pressure regulator?
oldestof11 wrote:Hate to be a Debbie downer but I (meaning me, myself, no other party involved) just see this as a crutch. The mentality is "Well, this is cheaper and bypasses the problem points. Why deal with the problems? Lets just bypass everything." This WON'T be legal in ANY pulling organization other than RWYB and ODL classes.
Mike8061, the problem with that setup is the backfeeding into the case with no check valve.
