Swapping in another cam....
Re: Swapping in another cam....
Postby BC847 » Tue May 08, 2012 11:43 am
TheTowingCowboy wrote:So I could run the cam in my bone stock engine with no problem since its never been tore down or anything? SAWEET!
THAT has never been said. :!:
With the 188/220 cam, it is recommended that one check and confirm the PTV clearance.
Postby Tacoclaw » Tue May 08, 2012 3:53 pm
You think your engine has never been apart, but considering you're not the original owner you don't actuall know.
My old man was the original owner of my truck, so I know it had never been tampered. :)
Postby ahale2772 » Tue May 08, 2012 4:33 pm
same here, I checked the installed valve height of my head, twas stock, a good idea from zach when throwing the 188 in
anyways, how do you like the 188 BC?
Postby BC847 » Tue May 08, 2012 6:50 pm
ahale2772 wrote:same here, I checked the installed valve height of my head, twas stock, a good idea from zach when throwing the 188 in
It's pretty. It's got funky color strips around the shaft next to the lobes where it was induction hardened?
I'm in the house looking-up the torque spec for the damper. :P
Still putting it back together.
Postby TheTowingCowboy » Tue May 08, 2012 7:25 pm
I wanna say its 140 lol I forget now. And I know the engine wasnt tore down to the fact it still has allt he paint in place AKA there is paint on the head gasket. Lol
TheTowingCowboy
Postby Farmboy92_2009 » Tue May 08, 2012 10:08 pm
whats ya gna do with the old one??? :mrgreen:
92 - SOLD. new ride.... 96 CC LB Dually 4x4 auto - Goerend's TD Convertor & HD VB, Autometer EGT/Boost/Trans Temp, 5'' TBE 6'' tip, #100 plate, II Dragonflow 5x.016's, CAI. Sitting in the shed - DDP 042 DV's, 80'' long Trac Bars, and nice purdy Full Replacement Ranchand :) WTB - 4k GSK, 60 lb VS's, and a 64mm turbo.
Farmboy92_2009
Postby BC847 » Tue May 08, 2012 10:27 pm
TheTowingCowboy wrote:I wanna say its 140 lol I forget now. And I know the engine wasnt tore down to the fact it still has allt he paint in place AKA there is paint on the head gasket. Lol
It's 92ft/lbs IIRC. :)
Actually, I normally keep things pretty clean around the engine and often paint stuff when I have it apart. I say often, . . . .. this isn't one of those times. Just shut the hood and walk away. :roll:
Farmboy92_2009 wrote:whats ya gna do with the old one??? :mrgreen:
I've a local fire dept member who's got 1st dibs, else, fellow forum member The_Head has 2nd dibs.
I've got to get some pics of it (wear-patterns, etc) for myself and Zach. ;)
Postby ahale2772 » Wed May 09, 2012 6:23 am
were you happy with the wear or did it look bad?
thought it was allready in and running
Postby BC847 » Wed May 09, 2012 5:35 pm
ahale2772 wrote:were you happy with the wear or did it look bad?
Yeah, wear-wise, things look really good. I'll post pics eventually.
Nah, just now getting to it. Had to finish my Son's mess.
Currently pulling head-studs up to torque. Arrg! :?
Postby ahale2772 » Wed May 09, 2012 6:16 pm
whats "torque" for you? (how many ft-lbs?)
I have a buddy that bashes ARP all day long, says the arp cummins studs are junk and they break all the time yada yada....
I asked him what he was pulling them to, 175ftlbs he says...OK jay, I'm sure its the studs fault
Postby BC847 » Wed May 09, 2012 6:21 pm
I'm running A1 studs, washers and nuts as supplied by Haisley Machine. 135ft/lbs.
Pulling them from 100ft/lbs up to 135ft/lbs in 5ft/lb increments, 30 minutes apart. Have to eats me spinach!
Postby ahale2772 » Wed May 09, 2012 6:38 pm
hmmmm... who says to do it that way? Haisley?
the worst is hot retorques, pulling the injector lines to get the studs between the valve covers, ugh
Postby oldestof11 » Wed May 09, 2012 6:39 pm
ahale2772 wrote:whats "torque" for you? (how many ft-lbs?)
I think 150lbs is the recommended MAX... I most likely am wrong but I thought I saw that on CompD...
Postby BC847 » Wed May 09, 2012 6:59 pm
ahale2772 wrote:hmmmm... who says to do it that way? Haisley?
Haisley didn't say that. It's some low-key stuff I read on the Internets. Using a digital torque-wrench with audible approach/target signals so as to allow for stretch. As is, I've no fear of taking it out tomorrow evening and beating the sthi out of it.
Yup, hot-torquing isn't kewl. :shock:
Postby The_Head » Wed May 09, 2012 7:13 pm
BC847 wrote:I've a local fire dept member who's got 1st dibs, else, fellow forum member The_Head has 2nd dibs.
You can give my 2nd dibs to Tater as I can't really afford it right now.
The_Head
Users browsing this forum: No registered users and 382 guests
