Black93 wrote:I was 0 for 2 on CF buying a he351cw. Both were sworn to be good and after I got them and checked them, neither were. No matter what you pay for one, if the seller isn't willing to pull the exh. housing & send you a pic, I would pass on it.
BILTIT wrote:Ditto on shifting and not hitting zero boost.
Hansen01 wrote:i have had mine turned all the way up and did not have a problem with egts,(from a stop to 90, netted 1400 degrees.) Pulling the sled netted between 1100 and 1400. And i could pull trailers with it like that to a point. A little tuning and you can pull them all day long without getting to toasty.(Maybe a valet switch) Keep in mind i had quite a bit of timing with these temps to. Noticed that i run noticably warmer with my timing back down to stock.
As for spool up, i can shift every gear and never drop my boost gauge to 0.
Hansen01 wrote:Dont get me wrong, with the pump turned all the way up with a heavy load big hills will be your enemy in the temp range, but maybe if you did some afc tuning you could pull it off
As for pulling the sled, last year when i was running my hx 35 and no intercooler i pegged my 1600 degree gauge at half track... motor temp was at 220 when i got to the end...
Hansen01 wrote:Without effort at 10lbs of boost? You must shift faster than me
