by RCCUMMINS89 » Sat Apr 06, 2013 12:54 pm
Ok, I've got it dialed in where it runs the best.
I'm actually about 1/16-1/32" backed off where my timing was with the smaller injectors....this helped clean up my low end smoke. (remember I'm now injecting the fuel in at a higher compression ratio)
Backed my power screw off about 1.5 turns.....
Puts me at 1400 degrees instantly and about 47 psi instantly. Truck has way more bottom end than before, is tremendously quiet and way more responsive than smaller injectors being overly maxed out.
Truck has a little less peak hp so on the dyno would make probably 375hp..... but it does pull a lot longer and therefore is a lot faster...... hammers 20-80 before temps get to 1600.
Kind of odd about the timing with these sticks. Where it is it sounds like a completely stock non i/c truck. If I advance it at all it sounds like it has 30 degrees of timing and surges badly. A little bit makes a huge huge difference. Where with the old injectors it didn't.
89 RC on shortened 92 diesel frame - NV4500 w/dual disc/4.10s on 37s. - Self built pump, "hot screw", lots of timing, True high volume low pressure lift pump, 62fmw/68/.7gated, 77lpm SAC Inj., Studs/O-rings,- 423/1220 Mustang - 11/16/2013
http://www.TheHungryDiesel.com full line dealer, if you don't see it please ask.
