He351cw install on 93 w-250
Re: He351cw install on 93 w-250
Postby Dodgetruck74 » Thu Nov 28, 2013 2:06 pm
Oh ok. So you just cut the steel tube down and use a peice of longer hose to go down to the block? And what did you do for a boost tube to the I/C?
Dodgetruck74
Postby DMan1198 » Thu Nov 28, 2013 2:26 pm
Sutter1stgen wrote:
DMan1198 wrote:it'll run fine up to 10 degrees off center
I have often wondered if there really was a set number. As I've track packed a few overpasses, and slopes with a dozer.
I was in a serious reclined position for hours on end, 1:1,1.5:1, and even some 2:1 slopes. That turbo didn't auto level, and it lasted.
Not knocking you, I'm curious as well to know a definite answer as to what is too much permanent incline for turbo to last. For all I know as long as your feed is still your feed, and your drain is still your drain, you may be good!! Lol
I understand. I got it from a install sheet from Borg Warner. This was just during mounting of the turbo. It said more than that and it "can" cause draining issues.
Postby Joecochrane » Fri Jan 17, 2014 10:23 pm
My motor is a industrial cummins my turbo sits on top of the manifold and from the factory the turbo oil feed line sits at about 2 o'clock. So a oil angle must not matter.
The driver 02 2500 ho 6 speed 2wd lil lift 35s edge cts hot some injectors and a fass
The toy 87 f350 39.5 tires 180 bus motor 727 trans maxed pump ground pin bumped timing 366 spring hx35 and a lot more in the works.
Joecochrane
