Help Begle build a new engine without actually doing so!
Re: Help Begle build a new engine without actually doing so!
Postby RCCUMMINS89 » Mon Aug 11, 2014 7:20 pm
What turbo are you running?
Postby Begle1 » Mon Aug 11, 2014 9:38 pm
64mm VGT.
451ve I believe.
Seems to still spin after getting roasted when my engine died.
Postby RCCUMMINS89 » Tue Aug 12, 2014 1:26 pm
Plan on I/c or non I/c pistons with the next engine?
Marine bowl pistons.... extrude honed 370s will be AWESOME
I/c bowl... 5x14 SAC injectors, maybe a 5x16
Postby Begle1 » Tue Aug 12, 2014 5:06 pm
They're going to be standard intercooled pistons.
5x14's sound tiny.
Postby RCCUMMINS89 » Tue Aug 12, 2014 9:01 pm
Hey now... 5x14 may sound tiny, but I like my stuff clean. What size were you thinking?
Postby Begle1 » Thu Aug 21, 2014 3:45 pm
Is it worth to balance and polish the crank or connecting rods while I have everything apart?
What about any sort of coating on the pistons?
I'm thinking I'm going to end up with .020-over non-intercooled pistons?
Stock piston-rings still the best?
Hell, injectors are the easy part...
Postby DodgeFreak » Thu Aug 21, 2014 5:01 pm
From the little bit of dabbling over on CompD I've read one person that used to coat pistons doesn't anymore because he didn't see any gains. I don't know if I'd coat the pistons. Polishing rods and crank I would but I also polished a tb for a 96 dodge intrepid lol.....I'd balance the rods and the pistons and the rod and pistons together.
Postby RCCUMMINS89 » Thu Aug 21, 2014 9:33 pm
My thoughts on coated pistons...........on a normal engine you melt the pistons after so many seconds at extreme heats, so you coat the pistons. Now you'll stick the rings just a few seconds later. No gain.
Postby Begle1 » Tue Aug 26, 2014 2:25 pm
So what should it cost to have a crankshafted balanced and polished?
Postby RCCUMMINS89 » Tue Aug 26, 2014 4:35 pm
I jus had my new engine through the machine shop.... the short block to get bored .40 over, everything polished, and balanced..... came out to $600
