Big Plans!!
Re: Big Plans!!
Postby Jonnylightening » Tue Aug 05, 2014 3:10 pm
just outta curiosity besides the wheel whats the difference between the cheaper and FMW version? Sorry for all the questions Id rather get right answers then guess or learn the hard way
Jonnylightening
Re: Big Plans!!
Postby RCCUMMINS89 » Tue Aug 05, 2014 3:51 pm
The difference between the 62fmw and a "box stock" $700 charger.... is T3 housing, wastegated housing, machine work for the d/p flange to be right, and machine work for the compressor side to be right... and machine work for the oil feed line to be correct.
Re: Big Plans!!
Postby RCCUMMINS89 » Tue Aug 05, 2014 3:52 pm
What makes the 62 sweet is it has a 6 pad thrust bearing assembly, as opposed to a 3. It also has a cupped turbine wheel for higher flow, and faster spooling. The 62fmw flows with in about 2 percent of the 63 wheels.
Re: Big Plans!!
Postby Jonnylightening » Tue Aug 05, 2014 7:31 pm
BIG thanks guys!! I'll probably just go with the FMW then. Now who makes honed injectors?
Jonnylightening
Re: Big Plans!!
Postby RCCUMMINS89 » Tue Aug 05, 2014 8:09 pm
We specialize in honed injectors... the "competition injectors" on the site are honed injectors.
Re: Big Plans!!
Postby Jonnylightening » Wed Aug 06, 2014 6:15 pm
RCCUMMINS89 wrote:We specialize in honed injectors... the "competition injectors" on the site are honed injectors.
Looks like I'll be savin for awhile!!
Jonnylightening
Re: Big Plans!!
Postby Jonnylightening » Wed Aug 06, 2014 6:17 pm
Is there any vids of your truck on the interweb at all??
Jonnylightening
Re: Big Plans!!
Postby 93flatbed » Wed Aug 06, 2014 6:26 pm
Is there any good map charts for the FMW 62? I've searched but I've seen several different charts all claiming to be it but very different numbers.
Oh and new guy, sounds like a good plan so far. Fallowing these guys advice will have you whipping your friends trucks. We have a significant weight advantage. Best advice I can give is research as much as possible, learn from others mistakes and only buy the expensive stuff once.
93flatbed
Re: Big Plans!!
Postby oldestof11 » Wed Aug 06, 2014 6:28 pm
I'll be watching this!
Re: Big Plans!!
Postby Jonnylightening » Sun Aug 10, 2014 6:27 pm
Found this used?
Bullseye S362 V-Band Outlet 76.3/67.6 Turbine Wheel 0.70 A/R
Turbocharger Name - S362
Compressor Wheel Inducer - 62mm
Compressor Wheel Exducer - 80.6mm
Compressor Wheel Trim - 54
Turbine Wheel Inducer - 76.3mm
Turbine Wheel Exducer - 67.6mm
Turbine Wheel Trim - 79
Turbine Option - Outlet - V-Band
Turbine Option - Inlet - T3
Turbine Option - A/R - 0.70
Horsepower Rating - 350-680
Jonnylightening
Re: Big Plans!!
Postby Jonnylightening » Sun Aug 10, 2014 6:28 pm
Would this be a good possible choice or not?
Jonnylightening
Re: Big Plans!!
Postby RCCUMMINS89 » Sun Aug 10, 2014 7:22 pm
Do you have a link? Should be perfect.
Re: Big Plans!!
Postby Jonnylightening » Mon Aug 11, 2014 9:11 am
Actually found it on ebay. Its used but only has bout 800 miles on it. Anyway I can save I will:)
Jonnylightening
Re: Big Plans!!
Postby CumminsPower59 » Mon Aug 11, 2014 2:49 pm
RCCUMMINS89 wrote:Do you have a link? Should be perfect.
http://www.ebay.com/itm/Bullseye-s362-7 ... fd&vxp=mtr
Re: Big Plans!!
Postby Jonnylightening » Mon Aug 11, 2014 3:03 pm
Thats the one! He relisted it but guess hes gunna hold it for me :)
Jonnylightening
