What about these injectors?
Postby dpuckett » Thu Feb 01, 2007 10:28 am
Greenlead and I both have experience grinding fuel pins.
Daniel
Postby Paccool » Tue Feb 06, 2007 1:08 pm
Any update on the new injectors? Did you get them installed yet? Smoke issues???
Stan
93 D250, PDR cam,stage 2 head w/o-rings,twin turbos HX35 on top HT3B on the bottom,modified IP,piston lift pump,DDP stage 3 injectors,gauges,ATS ported manifold,4" exhaust,5" inlet system,oversized intercooler, rear sway bar, fresh paint
Paccool
Postby 90firstgen » Tue Feb 06, 2007 6:03 pm
jegs.com has the bullydog fuel pins for $125
1990 2x4, 3/4 ton, Getrag, Cummins N/I
3200 Spring
Full Fuel Screw maxed (+/- 4 turns)
Injector rebuild with bigger nozzles
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
14cm Wastegated Housing
Stan's 4"
90firstgen
Postby Fnschlaud4620 » Tue Feb 06, 2007 7:18 pm
No, the injectors are not in the truck yet.
My plans were to go home last weekend to work on it, but on friday we got dumped on with snow and I decided not to drive 3 hours in a blizzard. It probably would have taken me 6 hour to get there. Then It snowed all weekend so it would have taken forever to drive back to college.
Any how, even if I did Get them in there, I wont be able to tell any thing. The truck is kind of down right now. I am still finishing building the twins and some other little odds and ends like the exhaust, an intercooler system, and mostly I am tring to have it ready for spring.
Here are some pictures of my truck, as you can see it will be a while untill it is finished.
http://www.cummins-conversion.com/photos/showgallery.php?cat=500&ppuser=556&sl=f
Fnschlaud4620
