Getting the right gauges....
Postby JimmieD » Thu Feb 01, 2007 8:56 pm
Pete, that is just totally bizarre! I have been searching on the net for many months, typing every combination of search criteria I could imagine and NEVER SAW THIS WEBSITE! nobody ever told me about it before either.
THANKS!
JimmieD
Postby JLeonard » Fri Feb 02, 2007 12:45 pm
The 4BTA 250 uses a seawater aftercooler. They also have had bad problems with their injectors...tips breaking off. Don't know exactly why, but it has been a problem I have been reading about fior a couple of years in boatdiesel.com.
I would probably opt for an aftermarket performance injector rather than a stocker...that might circumvent a problem.
Hope this helps....good luck.
Jay
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
Postby JLeonard » Fri Feb 02, 2007 12:52 pm
Jay
JLeonard
Postby CAJUN 93 » Fri Feb 02, 2007 12:57 pm
that might just be the most screwed up avatar i've ever seen. :lol:
CAJUN 93
Postby PToombs » Fri Feb 02, 2007 2:01 pm
Jimmie, the site is fairly new, 2 months at most. Glad I could help. :wink:
I also know where to get gauges reasonable. If you're interested, send me a PM.
CAJUN 93 wrote:that might just be the most screwed up avatar i've ever seen. :lol:
Fits the owner to a T huh?
On edit; Is that her front, or his rear? On second thought, don't wanna know! :shock:
Postby JimmieD » Fri Feb 02, 2007 3:45 pm
Yeah, butt....
I'm sure the Marine 4BTA in a land based vehicle would be starving for coolant using that setup with a radiator. I need to get the big parts list and see what is available that crosses with mine.
More I read on that new forum the more I want to be moderate in my buildup and GO SLOW at it. Towing is problem #1, but I want this engine to last the distance also! So I'll probably go low mid-range on performance, maybe 150-175 HP? Safer for a while. Cummins refused to give me info on my injectors other than '7mm' so I'll have to ask more questions somewhere. Thanks for the help, guys.
I have a source but I'll PM on the gauges, Pete, thanks!
JimmieD
JimmieD
Postby JLeonard » Fri Feb 02, 2007 5:00 pm
I resemble that remark! :lol: :lol:
JLeonard
Users browsing this forum: No registered users and 69 guests
