5 inch exhaust
Re: 5 inch exhaust
Postby AHineman » Sun Apr 11, 2010 12:18 pm
Finally got the pics...don't look at the dirt,oil,etc.
http://i809.photobucket.com/albums/zz16/AHineman1stgen/my1993/DSCN0016-1.jpg
http://i809.photobucket.com/albums/zz16/AHineman1stgen/my1993/DSCN0020.jpg
http://i809.photobucket.com/albums/zz16/AHineman1stgen/my1993/DSCN0021.jpg
http://i809.photobucket.com/albums/zz16/AHineman1stgen/my1993/DSCN0019.jpg
http://i809.photobucket.com/albums/zz16/AHineman1stgen/my1993/DSCN0017.jpg
http://i809.photobucket.com/albums/zz16/AHineman1stgen/my1993/DSCN0022.jpg
I'm sure 4" would have been fine for my current setup, but the outlet on the s400 that will be installed this summer (along with the s300 and a lot of other things) is 5", so I wanted to run it all the way back. As to how much better 5" is than 4", I've only had stock and the setup I have now. I gained 2 psi of boost going to whats in the pictures. :mrgreen:
Re: 5 inch exhaust
Postby Ptothej » Sun Apr 11, 2010 1:16 pm
93DodgeCummins wrote:well when i get the money im going to get a 4 inch turbo back then. I think bullydog makes a turbo back
Sorry if this has been answered already, but bully dogs 4" turbo back is a 3" downpipe.. I run no muffler.. basically transfer case back is 4" off the '94's and up, then I kept the factory 3" down pipe cause its exactly the same :S and stole the 4" piece that goes from the down pipe beside the transfer case from the bully dog system..
'92 W250, 5spd, reg. cab, 2" lift, 4" dp, 4"exhaust no muffler, smoke screw bottomed out, star wheel bottomed out, full power screw maxed, BD fuel pin, BD 16cm housing (30psi), K&N air filter with a modified factory air box
Ptothej
Re: 5 inch exhaust
Postby Ptothej » Sun Apr 11, 2010 1:21 pm
93DodgeCummins wrote:just wondering because my buddy has one on his 99 dodge cummins and i really like the sound
My brothers g/fs dad has 5" magnaflow on his 05, and (I didnt mention that in my previous statement that I run 5" from just inside the frame out the side behind the rear tire), and idling mine sounds identical. His has a muffler, mine does not.
Ptothej
Re: 5 inch exhaust
Postby Ptothej » Sun Apr 11, 2010 1:42 pm
.....As to how much better 5" is than 4", I've only had stock and the setup I have now. I gained 2 psi of boost going to whats in the pictures. :mrgreen:[/quote]
x2
Ptothej
Re: 5 inch exhaust
Postby ofelas » Thu Jul 02, 2015 4:33 am
Whats the factory 3" good upto?
R12 = liquid bilit
ofelas
Users browsing this forum: No registered users and 69 guests
