by Remps » Fri Aug 03, 2012 9:45 am
For informational purposes, my bed mounted cooler measures 23" deep, 24" wide, and 1.5" thick, and the trans will run at about 140 degrees going 70 mph unlocked, fan on. With the fan off, temps get to 150, 155. This is just the truck, not towing anything. F2F is hooked up. Locking the TC drops temps to about 105. About 8 psi boost unlocked at 70, about 5 psi locked. To give you an idea on the F2F cooler effect on the trans, climbing a local ski hill with my truck, when it had 1 dinky electric fan on the rad, engine temps would get to second last line on the temp gauge, trans temps hit 185,190 degrees, both fans on the whole climb. (1st gear, 10 kph, 2wd) It now has a fan off an intercooled truck. Now it will climb the same hill without engine temps climbing at all, trans temps hit 150 without turning the trans cooler fan on. And imo, if you are going to tow with a non lockup auto, you should have a BIG transcooler. I need to put a 2nd fan on mine to get the most out of it, it only has 1/3 fan coverage right now. Rant over...
![Gear Happy :grin:](./images/smilies/gear_happy2.gif)
