by motorwood » Thu Jul 05, 2012 1:02 pm
Compression is 400lbs, yes timing is a tricky thing to chase, the a1000 is showing to make over 100psi on both my pressure gauge and my case pressure gauge. I agree that stuff like no AFC, too large a turbos are hurting my HP. I was just thinking that fuel seemed to drop out early and it's worse now than on that 455 run. My smoke clears up and I can hold the pedal almost indefinitely and not break 1700* egt. I should study some of the big guys dyno sheets and see if their power is all in by 2500 rpm. Thanks again for all the good suggestions.
And I guess I didn't want to spend the money to bench it unless that person knew what to do to improve it.
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857
![Sad :(](./images/smilies/icon_sad.gif)
13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
