by KTA » Thu Oct 18, 2007 8:01 pm
Fwiw my head has stock sized valves with a five angle grind at 45deg. The intake port is the worst restriction in the head, and big valves will help low level flow but loose velocity. We need velocity to make swirl in the piston chamber to help burn the fuel. Big valves are for bigger rpm motors than the ve can do.
