Full cut delivery valves???
Re: Full cut delivery valves???
Postby Sutter1stgen » Mon Sep 24, 2012 12:08 pm
Maybe the lift pump helped a little. But it would still be nice tomsee where you cut as well!! Thanks.
Eric
Sutter1stgen
Postby cummins12club » Mon Sep 24, 2012 7:39 pm
I'll do my best to try and post a pic
cummins12club
Postby mhuppertz » Fri Nov 02, 2012 8:21 am
cummins12club wrote:I'll do my best to try and post a pic
A whole second is a lot. I want to see pictures too!
mhuppertz
Postby cummins12club » Fri Nov 02, 2012 10:09 am
A half a second not a whole second I just got a set machined and they should be done next week so ill try to figure out how to post pics but like bc847 said unless u have a turbo w a 9cm exhaust housing I don't know if u will notice a difference because they ate supost to be 40cc more fuel at rpm below 1500 rpm I can't say for sure a cc number they add or hp or even if they will help all I know is I noticed a big spool up difference and throttle response on the street and 5 tenths faster at the track keep in mind as well I replaced my lift pump at the same time so that could have had an added effect as well
cummins12club
Postby mhuppertz » Fri Nov 02, 2012 10:14 am
With my 16cm (and POD's) I already have too much fuel below 1,500... but if I can get that supercharger blowing into my turbo properly I will be looking for more fuel down low.
mhuppertz
Postby dazedandconfused » Sun Nov 18, 2012 4:20 pm
Follow the link in my sig to learn how to post pics.
