Its prob an 83mm exducer if its stock. I got the 62mm x 86mm. I also bought a new bearing housing that was already machined for the 86mm exducer. I prob should have done the 60mm instead of the 62mm. So, I ended up with a 62/60/16 non gated,,,,which people tell me is a combination that may cause surging. It spools(starts to build boost at about 1600rpm). With 5x.014 injectors 3200spring, I get peak about 32psi. I don't know if these numbers are good or not. This is my first cummins, first mods. I do know it seems to be twice as fast as it was when I drove it home stock. I have let off of the throttle abruptly a few times and have heard no sign of bark. From a dead stop, I am not sure i may hear like a quack if I floor it once it spools. I have heard that shouldnt be done, one should go for a boosted launch.
Housings, rebuild kit and machine work all add up no matter how you look at it though. You may just be able to get a new seal plate($20 and o-ring). I have heard to buy only the original Holset rebuild kits. I dont know, I have about 4,000 miles on this with BAE's version. There doesent reall appear to be anything rocket science in there. 2 journal bearings, snap rings. oild slingers??? Any how, I talked to Bob from Bae on the phone tell him what you want/need, you may save a little bit. If you want I could take some videos of driving at certain rpm with the egts and boost and stuff if it helps. I forgot if you had an intercooler or not, may make a difference.
http://s1256.photobucket.com/albums/ii4 ... ken-Turbo/
