Mark Nixon wrote:Is there ANYONE out there pulling 400HP out of a stock VE?
No? Why? Because it won't fuel it.
The VE is a dog for top end fueling, but it makes up for it by being good on the low end grunt, just gear taller.
The VE pulls hills just fine, it pulls sleds just fine, all while fueling BEST at low RPMS, where torque is needed.
Even a dumbass like me knows the best thing to pull with is something that makes the best torque down low, BUT there's only so fuel you can move with a limited design like a pump with 1 barrel to feed 6 cylinders.
Want to make REAL impressive numbers AND pull off the line hard?
Invent reliable Dynamic timing for a P-7100.
RCCUMMINS89 wrote:Well... if one counts fuel screw, gov spring, and fuel pin..... 99% of 400hp ve's are considered stock.
But I don't follow what a stock ve has anything to do with the conversation. A stock p pump doesn't produce much more than a stock ve
cmann250 wrote:Lets play a game. How about we not FUBAR every VE pulling thread that comes up. Obviously we can't handle it.
I like pulling and informative threads like this, but everytime the rampant speculation over runs fact.
Mark Nixon wrote:Puhleeese!
Some people don't question the information ENOUGH, then get all pissed off at bad results when they do something some schmoe on these forums
said to do while the "expert" is leaving out some critical information.
oldestof11 wrote:Mark Nixon wrote:Puhleeese!
I am calling you out on this one. You're afraid to turn the power screw, much less do anything competitive yet you are throwing out there what "should" work vs some people have done it.
turboram wrote:Wow sorry for starting this derail
Mark Nixon wrote:You're not going to bait me in, Jon.
