thinking about getting injectors worked on
Re: thinking about getting injectors worked on
Postby RCCUMMINS89 » Sun Jan 04, 2015 1:32 am
Ya...but it has the same resultas putting in huge injectors in Jaeger and keeping rail pressure stock.....with a single cp3
Postby DMan1198 » Sun Jan 04, 2015 3:53 pm
I Know someone who's done just that like a few days ago. Moparproud just put 200% overs in his 07 with triples, and stock cp3. Helped bottom end a bunch, but yeah it barely holds 20k on a little tune.
Jaeger will get duals before the 200% overs go in though
Postby RCCUMMINS89 » Sun Jan 04, 2015 4:37 pm
I'm surprised its even holding that much. I know Anarchy recommends going dual cp3 with anything over about 50% over at max.
Postby DMan1198 » Sun Jan 04, 2015 4:40 pm
Yeah. His issue is the primary piping runs across the top of the head for some stupid reason, so fitment is an issue with dual fuellers
Postby 1992gen1_fan » Thu Jan 08, 2015 9:02 am
Got to test the injectors on a cold start. It was 0*F this morning and they still idled pretty clean. Even while it was idling at 4-500 rpm lol
1992gen1_fan
Postby RCCUMMINS89 » Thu Jan 08, 2015 9:38 am
Honing... it's what to do. Makes things run as clean as their original size, but make the power of what they flow. If done properly that is.
Postby 93DodgeCummins » Thu Feb 26, 2015 2:21 pm
Did you notice any mileage differences after honing the stockers?
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Postby 1992gen1_fan » Tue Mar 17, 2015 5:04 am
Its hard to tell if im getting any better mpg compared to the 5x12's. I should be able to tell pretty soon now that the weather is stabilizing. Been a hard winter for mpg's lol.
1992gen1_fan
Postby 1992gen1_fan » Thu Mar 26, 2015 11:49 am
93DodgeCummins wrote:Did you notice any mileage differences after honing the stockers?
I think they've finally switched back to non winterized fuel. So far I haven't noticed much gain I'm mpg vs the 5x 12's. Maybe 1/2-1 mpg. I'll put a couple more months on them and report back. I do still need to re-adjust the IP to work with these smaller injectors so that may affect mpg a little, for better or worse I don't know yet :lol:
1992gen1_fan
Postby RCCUMMINS89 » Thu Mar 26, 2015 1:04 pm
I've never seen where injector choice affects mileage. Timing is the main cause. Unless of course one drives differently between different injectors.
Postby 1992gen1_fan » Thu Mar 26, 2015 3:20 pm
RCCUMMINS89 wrote:I've never seen where injector choice affects mileage. Timing is the main cause. Unless of course one drives differently between different injectors.
OK so just old worn out leaky injectors verses clean new ones would most likely be what would make a difference
1992gen1_fan
Postby RCCUMMINS89 » Thu Mar 26, 2015 7:26 pm
Correct.
Postby 1992gen1_fan » Mon Mar 30, 2015 7:57 pm
Thought I'd add that I added up my January through March 2014 vs 2015 MPG averages and their almost identical with 0.3 mpg better this year lol. So I'd say there probably isn't much difference in mpgs. I will check later with the warmer weather mpg averages. 13.26mpg is my average this winter BTW :shock:
1992gen1_fan
Postby RCCUMMINS89 » Mon Mar 30, 2015 8:10 pm
Wow, that's terrible mileage.
Postby 1992gen1_fan » Mon Mar 30, 2015 8:58 pm
RCCUMMINS89 wrote:Wow, that's terrible mileage.
Yea, I need to send the VE in to get looked at by another reputable rebuilder someday. There is a timing issue internally I think. Beside that, the flatbed took about 1-2 mpg away when I installed it and at least half of the miles I put on it are city and dirt road miles.
1992gen1_fan
