Trying to tune my hx35/ ht3b combo.
Re: Trying to tune my hx35/ ht3b combo.
Postby Remps » Sun Oct 11, 2015 11:45 pm
Check out "92 dodge turbo cummins diesel vs corvette" on utube. That truck runs mid 13's launching in 2nd. No idea what that truck has for a clutch, but I'd want a dual disk for 3rd gear launches, as it'd take some abuse to get it rolling and not bog out.
Postby 9312v » Mon Oct 12, 2015 4:23 pm
I could do about three to four launches with my organic south bend single disc before it started feeling weird, is also a nv4500 and was a single back then. Also got less than 35k out of it so I wasn't particularly easy on it.
9312v
Postby LandTug2 » Mon Oct 12, 2015 8:21 pm
Remps, ive seen that video. That truck kicks ass. Says its a getrag with a 12mm ve that dynoed 472hp at 2300' id be happy with it :D
'93 D250 5x16s, Stg1 pin, 3200 gov spg, stiffer afc spring, pump tuning, Super Harmonic Damper, Timing Spacer, hx35/ht3b compounds, 100 gpm lift pump, 12" Cone filter, Moog Springs, pyro/drive pressure/boost/f. pressure/tach gauges,valet switch, 4'' straight pipe, mag hitec dif cover
LandTug2
Postby LandTug2 » Mon Oct 12, 2015 8:26 pm
Damn thats a quick turn over on a clutch! Guess you gotta pay to play. Good to know what to expect though
LandTug2
Postby oldestof11 » Tue Oct 13, 2015 11:55 am
I talked to both SBC and Valair about clutches for racing. Estimated 600HP on nitrous.
SBC wanted me to do a exotic 13" single. Something like a Sintered Iron with a 4200lbs clamp force. Caveat: Needed a flywheel and clutch rebuild every season. Pro: cheaper up front. (Like $900-$1000)
Valair said NO SINGLES as they heat up too quickly. He has a racing/street triple. It is an 11" triple. Less rotating mass so it would shift quicker than a traditional 13" dual disk. Also it would have been organic faces so more street friendly. However, it was around $2300 at the time. His big pro about this was with all the clutch face available, it can load the engine better with more surface area needing it be heated up before it started burning up the clutch.
Postby 9312v » Tue Oct 13, 2015 1:01 pm
I put down 305/615 or 315/605 I cannot remember. Mind you I was not easy on that single at all, it started letting go shortly after I got new injectors. This time around I went Valair ceramic dual disc.
9312v
Postby LandTug2 » Thu Oct 15, 2015 8:44 pm
That 11" triple disc sounds sweet! And you said it is supposed to reduce rotating mass and give quicker shifts? (or they say). I estimate my truck at about 350 hp. Really need to hit a dyno to really know. Hopefully my OFEK holds up. Only time I have smelled clutch is when I was trying to build boost by riding the break in second... didn't work too well haha. Any one know Kurt Steiner's screen name from that video mentioned in the post above? Just curious about his setup as if I could make my truck run that good, Id be happy. Especially on a 12mm VE!
LandTug2
Postby Remps » Thu Oct 15, 2015 9:52 pm
I believe that is/was GLHS truck, he is a member here. Iirc....73 lpm DDP injectors, 1.95 mm timing, 62/71/14. Haven't seen him on here for quite a while.
Postby LandTug2 » Sat Oct 17, 2015 9:07 am
Ahhh yea I remember him. Also heard he went to an NV4500 and its eating through 3rd gears haha.
LandTug2
