oldestof11 wrote:Also, the issue with some is NOT the stock is better than the aftermarket, just the aftermarkets are cut too deep causing the AFC housing to get filled from the pin going past the O-ring. They say they get just as much fuel with a custom ground fuel pin effectively without the need for a deeper cut pin.
^^^^^^^^^^THIS^^^^^^^^^ You can get full travel out of a ground stock pin. I was getting full travel out of a very mild grind.
