delivery valves?
Re: delivery valves?
Postby turboram » Sat Feb 02, 2013 8:54 pm
Well the valves made about 20 rwhp difference..... BUT the tach pickup was going haywire so no accurate torque numbers. We ended up running hp only. And then the printer was acting up so I'll have to pick up the printouts later,then you all can see them. Must have been the wet dripping trucks ...The hp number was low as I expected with this dyno only 340 uncorrected :( talking to one guy there he said on his 600hp truck it was 150 hp off from 2 other dynos he's been on :/ so thats like 25% off so that makes mine 425hp :mrgreen: plus we were in a not so well ventilated shop with 2 bullet heaters and it was humid and it was so smokey that I've been blowing black buggers out for the last 6hours, but those are my numbers if I really want better ones I will run somewhere else. So with all excuses aside the best number was 410 uncorrected with a little of my own special blend of water meth additive .
turboram
Postby RCCUMMINS89 » Sat Feb 02, 2013 9:56 pm
That's about a 5% gain in hp with the del. valves.
However, this doesn't show what it does for the curve....
Postby oldestof11 » Sun Feb 03, 2013 5:48 am
Where did the HP peak at?
Postby turboram » Sun Feb 03, 2013 6:17 am
I'll let you know the specifics when I get the printout....never looked at the grafts too close because I had to get home as soon as I was done. But the operator said the power was pretty flat and fueled past 4000rpm. I was running the truck
turboram
Postby Remps » Sun Feb 03, 2013 5:48 pm
I'd like to see what kind of difference these will make on a 14mm pump. Ahem..jqmile? :grin:
Postby turboram » Sun Feb 03, 2013 9:46 pm
My plan is to use them on a 14mm I have in a couple of weeks on my VE 24 valve build
turboram
Postby D-dog357 » Mon Feb 04, 2013 8:45 am
Don't mean to hi-jack but what's with the "stock Ford fuel pump" ?
I get the feeling it's something from a Ford med-duty. Is it better then the Airtechs or just what you had laying around. ??
Come on give it up - nosy people want to know !!! :lol:
'92 ex-cab, A/T, 3.56, timing bumped 1/4" , 366 w/ fuel 1/2 turn past collar, smoke all the way out and a ported HX hot side. Airbox and core support drilled for more cold air.
A no budget work truck.
D-dog357
Postby turboram » Mon Feb 04, 2013 12:58 pm
Factory ford in tank gas pump...... :roll: not ideal at all
turboram
Postby Remps » Mon Feb 04, 2013 1:36 pm
Do you have a fuel pressure gauge? Don't some FI gas fuel pumps put out 40 psi?
Postby turboram » Mon Feb 04, 2013 5:11 pm
Fuel pressure is regulated to 20psi
Check out these pictures of delivery valves the top one is i/c and bottom is non the bushing is the only difference between the two but it has a smaller hole the hole is however the same size as the injection lines. So this may be the reason some people have said the non i/c d/vs are bigger http://s568.beta.photobucket.com/user/8 ... sort=3&o=1 Image
turboram
Postby hiboy_76 » Fri Feb 15, 2013 11:37 am
The only difference between non ic and ic DVs is the actual holder. They are longer which holds more fuel than the shorter than the ic ones(As you can see in the pic). Correct me it i'm wrong.
Back to the delivery valves, did anyone find a part number for them?? I am interested in trying them out on my 12mm pump 8)
91.5 W250 5spd, Kenny Smith Dual Disc, 100hp injectors, pump tweaked, 3200 spring, hx35
89 D250 pump tweaked.
hiboy_76
Postby VanillaGorilla » Sun Mar 03, 2013 8:00 pm
Bump. Anymore info available?
93 Reg cab LE 4x4 518AT, 145k and counting, pump turned up,Internal pump mods, Denny T stage 2, non IC DV's, timing bumped up, BD 40hp injectors,BHAF and me-built mandrel bent CAI,4" turbo back, Holley lift pump, new white with gold paint job, recieving more mods to tow the Duster and push this stupid WI snow.
VanillaGorilla
Postby blacksmoking » Tue Mar 05, 2013 11:43 am
I'm interested as well.
1993 d350 g360 Cummins, 5x20's non ic pump, Afro engineered fuel system. 2wd puller, Sled dragger.
blacksmoking
Postby VanillaGorilla » Tue Mar 05, 2013 3:30 pm
See that's two of us!
VanillaGorilla
Postby blacksmoking » Tue Mar 05, 2013 5:02 pm
soon there will be thousands interested, and they will have to reply with some results. :D
blacksmoking
