building a ve puller
Re: building a ve puller
Postby Mark Nixon » Sun Mar 10, 2013 3:06 pm
oldestof11 wrote:
Mark Nixon wrote:You're not going to bait me in, Jon. :P
Have you ever pulled a sled? Answer and then I will drop it.
Yes. Once. Worthless waste of time.
That's not to say there's no benefit.
Postby PToombs » Sun Mar 10, 2013 4:52 pm
Mark, I never knew you rode snowmobiles! I hate it when they break down too. :evil:
Postby dunes450r » Sun Mar 10, 2013 5:45 pm
torque is very nice, and does help, but even in pulling (sled or real world) its not the ONLY thing that matters, let alone the most important.
scenario: you're pulling a 15k trailer up a steep ass hill, are you going to be pulling that grade at 1200-1300 rpm where you have maximum torque??? HELL NO!! you're going to grab a lower gear and pull the hill at 2000-3000rpms........where you are making a lot more horsepower. same idea as sledpulling, torque might help get off the line, but you're not using much of that peak torque to get down the track!!!
dunes450r
Postby blacksmoking » Sun Mar 10, 2013 6:23 pm
From what I learned from other pullers is you get above peak power, then get pulled down into the power.
1993 d350 g360 Cummins, 5x20's non ic pump, Afro engineered fuel system. 2wd puller, Sled dragger.
blacksmoking
Postby blacksmoking » Mon Mar 11, 2013 6:04 am
I broke the shaft in the Lift pump, going to try to get them to warranty the pump. Hopefully they will send a new pump to me, I might put a pressure relief of a cutoff of some kind on it.
blacksmoking
Postby RCCUMMINS89 » Mon Mar 11, 2013 7:55 am
That would be nice if they warrantied it for sure.
Postby motorwood » Tue Mar 12, 2013 6:59 pm
You need to buy my input shaft and my 14mm be. Make me a decent offer on the package.
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857 :( 13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
motorwood
Postby blacksmoking » Tue Mar 12, 2013 7:22 pm
Is it just the 14mm rotor or the whole pump, More details please. I really don't want to put any money into the trans, I want to swap it to an nv
blacksmoking
Postby motorwood » Tue Mar 12, 2013 7:50 pm
Whole pump several thousand trouble free miles. Made 455 1080 with an hx40
motorwood
Postby blacksmoking » Mon Apr 15, 2013 5:24 pm
ok, I tried it out at a pull, I bought an airdog II 165 off a buddy, stuck it on, and the truck ran great, went to get ready for the pull, and I changed the turbo to an ht3b, with a giant exhaust housing, that we just happened to have laying around the shop. well I loaded the truck up, been real hard to start, and I was making oil. I decided to hook to the sled anyways, by the time my class was up my battery had died ( not real sure why), anyways, hopped it off went to the track, couldn't even get the sled to move the truck wasn't revving all the way up, died driving off the track. so Drug it home, pulled the pump, and the IC, radiator, fan etc, to bump the timing. going 2 teeth, turned it counter clockwise( correct?), and this is where I'm at, besides trading my cousin my old 19.5's for his HT60, what do y'all think about the ht60 twined with an hx35? Oh, i locktighted the new seal with red locktite, also asked the guy I bought the pump off of what fuel pressure it was set at 45psi :shock: , well I'm going to reset it to 20psi and go from there.
blacksmoking
Postby blacksmoking » Mon Apr 15, 2013 5:25 pm
blacksmoking
Postby blacksmoking » Mon Apr 15, 2013 5:27 pm
Also I bought a 75 dodge crew cab, I let my buddy pull it, listen to that slant 6 scream.
www.youtube.com/watch?v=JlFAtAc-QDo
blacksmoking
