7x10 vs. 5x12 - SAC @ 59LPM
Re: 7x10 vs. 5x12 - SAC @ 59LPM
Postby ellis93 » Thu Sep 26, 2013 6:28 pm
RCCUMMINS89 wrote:Been upwards of mid 90s the last few days and they don't haze a lick.
A little bit of this haze might have something to do with my engine and most other 1st gens being such high mileage rigs.
I do have to be honest in the fact that I simply enjoy the way these injectors drive though. I can lug the dog crap out of this thing and it rolls on with no issues. I just have a hard time without the performance end.
Well what's the verdict on this......
That last opinion sounds like it's changed some.
Postby RCCUMMINS89 » Thu Sep 26, 2013 6:59 pm
If it's above about 80 degrees outside they don't haze. If it's any colder they haze, colder the worse (this is at full operating temperatures of course)
However, keep in mind that I am also comparing these to other injectors that I have had in my truck.
Bottom line is the 7 hole sticks hazes worse than any proper spray angled injector that I have ever had.
Now............to some it might not be enough to care about, others will hate it. I don't like a hazing injector because when I'm hunting up in the mountains in cold weather. A mild "street haze" turns into a horrible smoke show that makes it unbearable to drive.
Postby brandonmgreer » Thu Sep 26, 2013 8:17 pm
ok. good to know. I just got a 92, bone stock, never turned up. gonna go a little mild with it to see what I can do for the best mix of power and economy... any suggestions RC?
I have a 4x4 p-pump to get stupid with:-)
brandonmgreer
Postby brandonmgreer » Thu Sep 26, 2013 8:19 pm
Sea level and hot 9 months out of the year too! We have two seasons... Hot and HOTTER
brandonmgreer
Postby RCCUMMINS89 » Thu Sep 26, 2013 8:25 pm
I'd probably recommend 7x10s in your case. Which I do carry 7x10 (genuine bosch, runs $500).
However, not knowing everything..............I may think diff. PM me when you want to talk about it.
Postby RCCUMMINS89 » Thu Sep 26, 2013 8:29 pm
RCCUMMINS89 wrote:If it's above about 80 degrees outside they don't haze. If it's any colder they haze, colder the worse (this is at full operating temperatures of course)
Saying the above............I don't want it to come across as I hate 7 hole injectors. The ONLY reason I don't run them...........my truck is in a situation 9 months out of the year that a mild haze turns ugly. The other reason is, I'm trying to make BIG power yet. Even though I'm about to say the heck with it.
Postby brandonmgreer » Thu Sep 26, 2013 9:46 pm
Thank you. I will pm you as soon as I have enough posts to do so...
brandonmgreer
Postby ellis93 » Fri Sep 27, 2013 6:03 am
I don't car for haze myself.
I still stand by what I said before tho,they didn't haze when I first installed mine. Mine started that when I pumped the fuel system full of trashy fuel. From there it's been a down hill run for my truck. New injectors cut some smoke,lessened haze, timing helped but it still ain't right. Now there's evidence that the pumps taking a dump.
Postby RCCUMMINS89 » Fri Sep 27, 2013 10:03 am
And I agree..........and stand by my previous statement that they may not haze in all vehicles.
They hazed worse than 5 holers in my truck. BUT my mess probably wouldn't haze if everything was fresh.
Also...........I live in somewhat rainy climate that is below 70 9 months out of the year. When it rains my mess hazes with everything (less air).
And lastly...........they DO NOT HAZE BECAUSE OF THE 7 HOLES they haze because of the larger SAC volume than our traditional 5 holers we use. They do lack the wot high cylinder pressure (30psi +) power though because of 7 holes and a ve pump. But they definitely make up for their power down low.
I also had no smoke issues except at idle.
Postby brandonmgreer » Fri Sep 27, 2013 10:23 am
i really appreciate the input guys. Doing some research into what I'm gonna use. The right combination of parts is never a bad place to start!
brandonmgreer
Postby Alec » Tue Oct 15, 2013 5:01 am
Hey RCC, how is your ksb set up? And did it have any effect that you could notice on the 7x10's hazing problem? I was just reading this article https://e-reports-ext.llnl.gov/pdf/235419.pdf and it made me think that retarding the timing at idle speeds with the 7 hole injectors might help with idle haze because you would be initiating injection into hotter air, and maybe form fewer soot precursors as the short burn started . . . I am probably totally misguided, but that's why I'm asking :) .
Thanks,
Alec
'91 W250: Getrag; 3.54's
Alec
Postby BC847 » Tue Oct 15, 2013 7:32 am
brandonmgreer wrote:Thank you. I will pm you as soon as I have enough posts to do so...
You are well past that point. Are you not able to send PMs? :?:
Postby RCCUMMINS89 » Tue Oct 15, 2013 8:36 am
Alec wrote:Hey RCC, how is your ksb set up? And did it have any effect that you could notice on the 7x10's hazing problem? I was just reading this article https://e-reports-ext.llnl.gov/pdf/235419.pdf and it made me think that retarding the timing at idle speeds with the 7 hole injectors might help with idle haze because you would be initiating injection into hotter air, and maybe form fewer soot precursors as the short burn started . . . I am probably totally misguided, but that's why I'm asking :) .
Thanks,
Alec
Sorry, I never noticed this post.
My ksb is deleted. I messed with the timing from near stock all the way up to way over advanced...didn't change the idle haze.
Postby Remps » Sat Nov 02, 2013 4:28 pm
A little off topic, but did you ever test those injectors with increased lift?
Postby RCCUMMINS89 » Sat Nov 02, 2013 4:43 pm
The ones I have in now you mean? The current ones in my truck are the 77lpm sticks that we did a mild .05 of lift on....... at first I thought I noticed an increase in fuel, but later I don't think it was any different. But we also increased the pop from 250 to 255 bar, which might have just made things even again.
Users browsing this forum: No registered users and 74 guests
