6.7 C/R to VE conversion OBSERVATIONS.
Re: 6.7 C/R to VE conversion OBSERVATIONS.
Postby jdslucky » Fri May 18, 2012 7:23 am
awesome amount of info in this thread! cant wait to see more pics
jdslucky
Postby Mark Nixon » Sun Jun 30, 2013 7:54 pm
Scratching an itch and reminding myself of key points. 8)
Glad I put this here. :D
Postby Mark Nixon » Tue Jul 02, 2013 11:24 am
An engine I bought a while back has yielded a set of 24 valve 7x14 injectors! :D
I can see this being a real stump puller, if this goes to fruition. 8)
Postby Mark Nixon » Wed Jul 17, 2013 7:44 pm
Any opinions on what turbo to run with the 7x14 injectors in this theoretical 6.7 build?
Postby SuperiorRam » Wed Jul 17, 2013 7:52 pm
Are the vp sticks going to have the correct spray angle for the 6.7 bowls?
92 Cummins: DD, basic mods, topper, 9'2" bossV
92 Cummins: 10' tall, Rockwells and r1's "Dirty Addiction",
83 RC/SB Cummins: engine set back 18", block 89w/h20 after cooler, fire ringed and worked head, studs, billet 64/68/14w/race cover, custom header, bigger sticks, 47rh, dana 60, four wheel disk, and big Mickey Thompsons w/ Weld drag lites. "The Mustard Bucket"
SuperiorRam
Postby AHineman » Wed Jul 17, 2013 7:53 pm
64/71/14 maybe?
Cheap box stock 63mm t4?
Postby Mark Nixon » Wed Jul 17, 2013 8:09 pm
SuperiorRam wrote:Are the vp sticks going to have the correct spray angle for the 6.7 bowls?
153* sticks, 146* bowls, difference of 7* and the 6.7 has a larger diameter bowl.
I have looked at 148* sticks, but they are no larger than stock VP injectors and cost $450.
IF the VP injectors have more tip protrusion than the OEM 6.7 injectors have, then it should turn out fine.
AHineman wrote:64/71/14 maybe?
I'll be honest, I have NO CLUE.
All I know is that an HE351cw won't stand a chance of working on this thing.
Postby AHineman » Wed Jul 17, 2013 8:13 pm
One of the cheap t4 s300s might be just the ticket with those big injectors and the added displacement of the 6.7, but I really don't know. I'll never have enough money to play with a 6.7.
Postby Mark Nixon » Wed Jul 17, 2013 8:23 pm
AHineman wrote:One of the cheap t4 s300s might be just the ticket with those big injectors and the added displacement of the 6.7, but I really don't know. I'll never have enough money to play with a 6.7.
If I hadn't bought the shortblock for under $1000, I wouldn't be "playing" with a 6.7, either.
If you figure what I have into it, piecemeal, it's not as much as some, but still a notable amount.
If I do what I am pondering doing, I'll have to get head studs and make sure the deck and head is square.
Then there is getting the pump set-up properly, because it's certainly not going to fuel these injectors very well as-is.
Postby AHineman » Wed Jul 17, 2013 8:34 pm
Cool to see you considering a performance build. Don't change your mind and sell it all.
Postby Mark Nixon » Wed Jul 17, 2013 9:04 pm
AHineman wrote:Cool to see you considering a performance build. Don't change your mind and sell it all.
If it becomes a PITA, it's gone.
I don't take adversity from parts very well. :lol:
Postby SuperiorRam » Wed Jul 17, 2013 9:11 pm
A s300 with the 73 turbine would be a minimum IMHO. I've seen 64mm s400 off a Detroit pree cheap on fleebay
SuperiorRam
Postby Mark Nixon » Wed Jul 17, 2013 9:23 pm
I appreciate the comments so far.
This isn't going anywhere if I don't get off my butt and finish tearing the shortblock down and get the block's face re-worked for the early timing case.
I also need to decide which cam to run (leaning towards the VP cam) and get a set of non-CR rods re-bolted and sized.
All in a time when parts selling is, shall we say, minimal. :roll:
Postby Torqued » Tue Jul 23, 2013 12:35 am
Not sure if the pic and info helps you out on your conversion or not, but here you go. http://keatingmachine.com/products/entr ... tsfeatured
Torqued
Postby Mark Nixon » Tue Jul 23, 2013 7:46 am
Thanks for the link. :)
IIRC, it was priced beyond my budget.
Users browsing this forum: No registered users and 74 guests
