ole shakey
ole shakey
Postby moparbubba » Mon Jun 27, 2011 8:05 pm
I've been building up my truck aka ole shakey for a few years part by part so far with the mods in my sig I've recently got a better job so more cash for upgrades. I've got two ag dual valve cover breathers low pressure piston lp on the way. So after they get here and installed I'm getting new injector line stock size ( 4 and 5 leak) and 5x14 injectors. And either a hybrid or s362 what would yall recommend I do next?
Ole shakey 92 club cab long cab D250 366 spring denny t afc delete pdp xtra length fuel screw m&h dynamic timing device rebulit tampered with 12mm ve dnr customs intake outerwears prefilter cooler tubz denny t grid delete pot tps 4inch diamond eye exhaust upgraded A518 and more junk bolted on.
moparbubba
Re: ole shakey
Postby Kasper Cummins » Tue Jun 28, 2011 5:49 pm
I would say get the S362 it would be a nice high pressure turbo in a twin setup, if you plan on doing twins. Do the mods you have planed and see what you need next that's the best way to do it.
92 W250 club cab
Kasper Cummins
Re: ole shakey
Postby moparbubba » Tue Jun 28, 2011 5:59 pm
Gona keep her a single I'm looking for 300hp 700ft lbs or so
moparbubba
Re: ole shakey
Postby moparbubba » Tue Jun 28, 2011 6:03 pm
http://www.dieseltruckresource.com/dev/ ... p?t=281221 here's a better description then my sig
moparbubba
Re: ole shakey
Postby moparbubba » Fri Jul 01, 2011 5:16 pm
got both breathers on
moparbubba
Re: ole shakey
Postby dazedandconfused » Fri Jul 01, 2011 5:29 pm
Not a bad looking old truck.
Re: ole shakey
Postby moparbubba » Fri Jun 15, 2012 7:40 pm
Ive done alot to her since ive posted on here
He351cw is in 4inch downpipe, low pressure piston lift pump dual fuel filter set up full set of gauges dnr customs injectors are goin in tommorow i dyno on the 22nd and cecil county dragway in a few weeks
moparbubba
Re: ole shakey
Postby moparbubba » Fri Jun 15, 2012 7:46 pm
dual filter set up
Lpplp
Drilled out banjo bolt
moparbubba
Re: ole shakey
Postby moparbubba » Fri Jun 15, 2012 8:08 pm
Dnr customs 6 hole extrude honed injectors Image
moparbubba
Re: ole shakey
Postby moparbubba » Fri Jun 15, 2012 8:11 pm
He351cw
New dog upgrade Image
moparbubba
Re: ole shakey
Postby dazedandconfused » Sat Jun 16, 2012 4:50 am
Looks like you are making good progress on it. Whag are your final goals for the truck?
Re: ole shakey
Postby moparbubba » Sat Jun 16, 2012 6:41 am
A farm truck sleeper.......my goal is to be a single turbo daily driver thats got 300-350hp still can work on the farm and tow some. Something i can have fun with but not be a dyno or strip queen.
moparbubba
Re: ole shakey
Postby dazedandconfused » Sat Jun 16, 2012 6:50 am
Sounds good.
Re: ole shakey
Postby moparbubba » Sun Jun 24, 2012 6:30 pm
New fuel sump 1/2 lines on the way.
moparbubba
Re: ole shakey
Postby moparbubba » Sun Jul 01, 2012 6:43 pm
moparbubba
