P-Pump conversion, Parts list
Postby Hansen01 » Wed Jul 06, 2011 10:14 pm
jus wondering what was all going to need changed on my 90 to run a P-Pump?
(may not get done tomorrow, but its gonna get done eventually) :D
Under construction...
Hansen01
Re: P-Pump conversion, Parts list
Postby gobigorgohome » Wed Jul 06, 2011 10:16 pm
not sure on the list exactly but i know a p pumper can be aquired from an 8.3 cummins too. gears anwhat not may be different but they have a p7100 on em
91 4x4 with the 727, has the factory tach!
Boost gauge installed 27psi, new exhaust manifold here just not on yet. Pyro installed all glowshift units. 173 HP baseline before poor mans 4 inch dp
gobigorgohome
Postby skilletky » Thu Jul 07, 2011 6:35 am
Front gear case, inj lines, injectors, throttle linkage, gotta pull the cam to swap the gear case.
skilletky
Postby Mark Nixon » Thu Jul 07, 2011 8:43 am
I have a whole 1995 engine for as much as the conversion will run.
It has around 300,000 miles on it and it runs okay, just needs a re-seal and it wouldn't hurt to throw a set of rings and bearings at it, too.
Or you could buy it and pirate the conversion off it. :D
Or I could just part the engine out, someone here needs a head....
Postby Hansen01 » Thu Jul 07, 2011 3:14 pm
thanks guys! :D
Hansen01
Postby Hansen01 » Fri Jul 08, 2011 3:53 pm
also would the injectors fit right into my head or would you need adapters or somethin?
Hansen01
Postby skilletky » Fri Jul 08, 2011 6:57 pm
Pretty sure the only difference in a p pump injector and a intercooled ve injector is the nop and the threads for the high pressure fuel line on a p pump injector are bigger. I think both are a 7mm tip with a 145 degree spray angle
skilletky
Postby Hansen01 » Fri Jul 08, 2011 10:51 pm
i do not have the intercooled pickup if that matters
Hansen01
Postby skilletky » Sat Jul 09, 2011 8:10 am
The pistons in a non intercooled motor are different, injectors in a non ic use a 155 degree I think. You will probably be better off swapping in a compleat p pump motor
skilletky
Postby mathews8pt » Sat Jul 09, 2011 8:48 am
It wouldnt be as bad running a 145* injector in a motor built for 155*, as it would be running a 155* injector in a 145* piston. I believe you can just use p-pump injectors with the adapters for your 9mm head.
I would just find a p-pumped engine if it were me...
2000 p-pumped 24v daily driver
1993 D250, 2wd, 5spd(for now), timed to head, hx35, PODs, electric fuel pump, ground pin. The new project truck...
mathews8pt
Postby Hansen01 » Sat Jul 09, 2011 9:25 am
could i not jus get the spray angle changes,say different tips when they get rebuilt?
Hansen01
Postby Dave 5.9 » Tue Mar 25, 2014 6:53 am
Are the cams the same? I have a 94 p pump going onto a 91 intercooled block. Do I use the 94 or 91 cam????
Dave 5.9
Users browsing this forum: No registered users and 66 guests
