ahale2772 wrote:i've been using the fitting on my pump to watch case pressure
ahale2772 wrote:so the fitting feeds fuel directly into the plunger so that it can stem the loss and try to keep case pressures up?
The snout is long so that it will block off the normal fuel passage from the case to the plunger
And what are you seeing, as far as case pressures go
